R33 Cold Start Issues
Hey guys
So every morning when i get into my car and start it, for the first few seconds (unless i rev it) my car coughs and splutters and occasionally stalls when its cold. No issues when warm. Im running a turbo RB25DET with warn out coils haha, what could be causing this?.
Cheers Alex
i got same problem, have to feather the throttle for 4-5 seconds before the auto chock kicks in and sits at 1600rpm.
Ive cleaned out the cold start valve under the inlet manifold, unsure where to go next
nope didnt fix my Issue Alex,
Its under the plenum, 2 x 10mm bolts i think, and 2 hoses and a plug.
Mine was gunked up, it somewhat helped, but the car wont start without touching throttle unless its already warm, or been sitting in sun half day.
GTSboy, cleaned all that, that helped the idle alot as it was on 500rpm when warm, fixed all that, reset TPS position etc etc.
Search the DIY section, think there is a Right up with pics showing how to clean the ACC, its at the back of inlet manifold. 4 bolts i think, few hoses and clips.
Pull down, clean, put back on. easy. took me hour going slow.
Also as a precaution get some throttle body and carby cleaner and wipe out the throttle body near the crossover pipe. I had some buildup of just "shit" in there. Affected my idle something chronic...
 Share
    • Hi there, after a quick google search I found this topic as I am also relocating the battery to the boot of my 1998 GTT. I was just wondering how you got on with installing the re-routing and specifically the installing of the harness protectors? How do they attach? Are they just a simple "click-in" affair, or do they attach with bolts? Does the GTT have all the necessary fixing holes for them, for example, where they locate on the chassis? Any help you can provide would greatly appreciated.
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
