Stagea Humans,
Just wondering if anyone is running 20s on their M35 and what specs they are? Looking at some 20x10s in a +38 which should theoretically fit, but would like to know what others have. Pretty handy with the old guard roller after all these years so a little bit of massaging is no issue.
Many Thanks im Advance,
Jeff
https://www.sau.com.au/forums/topic/423056-20s-on-m35/
Yes I agree with Alex I think you will have issues on the inside not the outside, I have 19*9.5 +35 and there is very little room to the suspension I have around 3mm to the strut.
Edited by richzx
https://www.sau.com.au/forums/topic/423056-20s-on-m35/#findComment-6807188
I only put them on Thursday and nothing as yet. I think a few others have run the same spec with no issue. When I think about it there must be more room because I tried on and drove with some 19*9.5 +38 as well. I will double check. I also have the Bilstein suspension in mine if it makes a difference?
https://www.sau.com.au/forums/topic/423056-20s-on-m35/#findComment-6807270
Wheels look ok but you need more offset or some spacers!
The killer is the Over Fenders.
The steelwork underneath is the same as the RS/RX, but the guards protrude out another 15 or 20mm, so you can't push the offsets too far unless you start cutting metal or going bananas with guard rolling.
Also, I think they need some more sidewall; the guards just swallow the wheels up with super low profile.
https://www.sau.com.au/forums/topic/423056-20s-on-m35/#findComment-6807657
Question for yah. If I run 19 x 8.5 I'm gay aye? Pity I cannot fit wider because I'd be hardcore like you then! IMO on the m35 if its white its gay!
Pfft. My 18x8 white rims look awesome! Could do with a fraction more sidewall though...
https://www.sau.com.au/forums/topic/423056-20s-on-m35/#findComment-6807849
Anything under 8.5" wide is not even a worthy upgrade IMO.
And if your into handling, make sure your 20's are not Tempe tyres/ taleb tyres / ozzy tyres specials.
Stuff I could cast a better circle in my daughters sand pit!
Better have bucket of lead to balance the suckers to.
Really a well made 19" is the performance limit.
Anything over your adding to much Unsprung weight and tyres will cost you a heap.
Just my 3 cents
https://www.sau.com.au/forums/topic/423056-20s-on-m35/#findComment-6807964
My 2c
First, the one car i have seen with 19x10+ wheels looked horrible. To add, it was also dangerous.
Second, people think buying wide rims and putting Ling Long tyres on them makes them a handling God. I'll take 30mm smaller, quality tyres over china spec any day.
And Christian, maybe you should check out what fits before offering advice. Not many of us are StanceNation orientated.
https://www.sau.com.au/forums/topic/423056-20s-on-m35/#findComment-6807979
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
    • re the security system, my Fuga/Q70 has the factory option where the puddle lights in the mirrors turn on when the prox key is detected, it was clearly dealer fitted and has a switch in the lower dash to disable it....it didn't have remote start but TBH I don't really miss that, I had it in the Stagea originally but never used it....we don't often have to warm the car up in the snow before we get in for Australia. And the Fuga also has the illuminated footwells, sounds like a useless feature but I actually quite like the indirect light within the car, it was a nice addition
