Hey been in here for a bit so time to make a build thread
This is my r32 got back in 2011.
came with hks ebc ,gtr bonnet/grill,3inch no name cat back,18inch lenso's
Stock rb20
Then the bug bit
Where its at now/ spent some moneys
Rb25det convertion
Hks gtrs turbo
Link g4 extreme fitted by peter at pulse tuned by mrc
Id725 injectors
Hks cams 256in 264ex keeping vct with hks ex cam gear
Nismo 2way lsd
Gktech hicas lockout
Gutted hicas i mean everything
R33 gtr front brakes gktech mod
Gktech castor rods
Vl turbo gearbox mx7
Hybrid intercooler
Jjr bellmouth dump pipe
First up it made 253kw with out cams
Drove it around fun till i got bored then fitted cams and picked up 276kw
On 98
Ran it at the drags in sydney ran a 13.1 shity tyres massive amounts of wheel spin
More to come- dylan
https://www.sau.com.au/forums/topic/423060-dylans-r32-gtst/
  • Replies 58
forgot to add fake greedy manifold and q45 throttle body
didn't take many pic when install rb25
this is when installing hks cams
picked up my rb30/det block from Duncan foster along with nitto I beams, ceramic/Teflon coated je pistons and bearing etc... still waiting on the 25 head which it is getting fitted with supertech 1m oversized valves.titanium retainers, double spring,solid bucket conversion supplied by me as I picked the kit up super cheap and as for camtech cams 274in 10.5mm lifed and 276ex 10.5mm lifted with vct yep VCT
as for oil pump massive overkill got a ross performance external oil pump set up good .quality setup!
not my motor
https://www.sau.com.au/forums/topic/423060-dylans-r32-gtst/#findComment-6815141
fitting hks cams
picked up my rb30/det block from Duncan foster along with nitto I beams and ceramic/Teflon je pistons bearing arp bolts etc
using 25 head which still waiting for
ports cleaned up
supertech:
1mm oversized valves
titanium retainers
double springs
soild bucket conversion
al suppled by me since I got it all super cheap!
camtech cams 274in 10.5lifted 276ex 10.5 lifted
nitto oil head drain
nitto head gasket
precision 6262 bb turbo
turbosmart 50mm wastegate with screamer
oil pump massive over kill ross performance external oil pump
not my motor borrowed pic
https://www.sau.com.au/forums/topic/423060-dylans-r32-gtst/#findComment-6815158
  • 3 weeks later...
bit of progress made change the front two wheel bearing as they were rooted ..turbo arrive thanks pj's quick bits top bloke! and sump is finished just need to weld some fitting on then fab up turbo manifold and fit a 50mm waste gate. hoping to get it started and ran in before tamora 1000 and powerplay .not to sure wat to go with as for a clutch
https://www.sau.com.au/forums/topic/423060-dylans-r32-gtst/#findComment-6864802
  • 1 month later...
post-88690-0-63162300-1374299465_thumb.jpgmassive update:
motor has been swaped rb25 is out and rb30 is in....
25 getting puted out
rb30 goin in.. have some problems with the height of the motor protruding in to the bonnet .ended up cutting the bonnet brace and stuffing around the mounts got about 10mm clearance between the bonnet and timing cover
didn't get many pictures but most of you get wat a rb looks like
made up a turbo manifold didn't want to fork out $$ for a 6boost
toke me a day to make and half a day to tig weld looks great was impressed how it turn out :)
sent it to j and j in penrith to get coated black with the rear housing
went back to ross at ross balancers and picked up a trigger kit
https://www.sau.com.au/forums/topic/423060-dylans-r32-gtst/#findComment-6935940
  • 1 year later...
Lol yeah mate it was all i had but wasnt to bad for its first outing
That mph works out to be 9.7 on the moroso calulator so sould see a mid 10
Should get the the new clutch today and a set of mickey tompsons
Might try and get rid of some of this rear camber to may help
https://www.sau.com.au/forums/topic/423060-dylans-r32-gtst/#findComment-7355011
  • 6 months later...
  • 1 month later...
