R32 Gts-T Nsw Plenty Of Mods
Hi all
I have for sale my R32 GTS-T. I hadn't planned on selling it, but I'm now looking at buying a GTR.
It's a 1992 R32 GTS-T, I've owned it for over 5 years since the odo said 130,000kms & its now showing 210,000kms. Been a daily driver for most of its life, still puts out around 150kw at the wheels at 13psi on standard motor, turbo & ECU. Very reliable at this power level, never had any major issues other than general wear & tear maintenance. Oil & filter changed every 5000kms religiously.
I've been upgrading everything in the car ready for an RB26 conversion, & it's pretty much ready to go in right now. Mods are as follows:
R33 GTS-T front brake upgrade
BRAND NEW Exedy single plate clutch rated to around 700hp
rebuilt & shimmed factory LSD
upgraded UAS radiator
GTR front seats
GTR dials put into standard GTS-T dash
DVD player with separate 7" display screen
splitfire coils
walbro in tank fuel pump (500hp rating)
rb25 pink label AFM fitted & calibrated by Unique Auto Sports
turbosmart dual stage boost controller (11psi & 13psi)
17" black R34 GTT wheels (optional set of 17" antera wheels also but only has 2 good tyres on this set)
3" catback exhaust
aftermarket coilovers (just over a year old)
GTR bonnet with N1 lip & GTR grille (grille needs to be painted but i still have some paint left over)
dual pillar mount boost gauges (1 shows pressure in bar, other in psi)
Plenty of other mods I'm sure I've forgotten, car is due for its next 100,000km service so only gets driven short distances on weekends mostly. (I've been holding off to do the RB26 swap). I can look into getting this service done prior to purchase if requested.
Registered until June 2013, not had issues with rego or police for the past few years. (got defected once before & cleared before rego was cancelled, i was running a silly BOV & pod at the time, all plumbed back now).
Bad points:
clear coat is peeling in a few places, behind drivers door under quarter window & on the roof just behind the front windscreen
aircon needs a regas, was working fine until it ran out & i left it planning on the engine swap
central locking plays up, but the car can always be locked
alarm isnt making noise, but the immobilisers still work fine
passenger window isn't currently working, i believe due to the alarm auto-window lift malfunctioning. if you put power on the motor inside the door the window operates fine, & the switches are working fine also.
Located in western sydney close to minchinbury
Asking $7500, NO SWAPS PLEASE, i already have WAY too many toys.
OR
Price with included extras $13,000.
Extras
RB26DETT (N1 turbos, gates timing belt & modified RWD sump approx 9 litre capacity just fitted)
RB25 box & custom 1 piece driveshaft
PowerFC (& hand controller but unsure if it suits GTR, purchased separately & not tested)
Link to pics: http://s979.photobucket.com/user/cmoney9630/library/R32%20GTS-T?page=1
Any other pics you want that aren't already there, let me know as I may have some floating around.
PLEASE NOTE: extras are NOT for sale separately unless the car gets sold on its own first, thank you.
Best contact on here via PM, or 0407 896 339.
Cheers
Chris
Edited by cmoney
  • 1 month later...
 Share
