Hi all
I have for sale my R32 GTS-T. I hadn't planned on selling it, but I'm now looking at buying a GTR.
It's a 1992 R32 GTS-T, I've owned it for over 5 years since the odo said 130,000kms & its now showing 210,000kms. Been a daily driver for most of its life, still puts out around 150kw at the wheels at 13psi on standard motor, turbo & ECU. Very reliable at this power level, never had any major issues other than general wear & tear maintenance. Oil & filter changed every 5000kms religiously.
I've been upgrading everything in the car ready for an RB26 conversion, & it's pretty much ready to go in right now. Mods are as follows:
R33 GTS-T front brake upgrade
BRAND NEW Exedy single plate clutch rated to around 700hp
rebuilt & shimmed factory LSD
upgraded UAS radiator
GTR front seats
GTR dials put into standard GTS-T dash
DVD player with separate 7" display screen
splitfire coils
walbro in tank fuel pump (500hp rating)
rb25 pink label AFM fitted & calibrated by Unique Auto Sports
turbosmart dual stage boost controller (11psi & 13psi)
17" black R34 GTT wheels (optional set of 17" antera wheels also but only has 2 good tyres on this set)
3" catback exhaust
aftermarket coilovers (just over a year old)
GTR bonnet with N1 lip & GTR grille (grille needs to be painted but i still have some paint left over)
dual pillar mount boost gauges (1 shows pressure in bar, other in psi)
Plenty of other mods I'm sure I've forgotten, car is due for its next 100,000km service so only gets driven short distances on weekends mostly. (I've been holding off to do the RB26 swap). I can look into getting this service done prior to purchase if requested.
Registered until June 2013, not had issues with rego or police for the past few years. (got defected once before & cleared before rego was cancelled, i was running a silly BOV & pod at the time, all plumbed back now).
Bad points:
clear coat is peeling in a few places, behind drivers door under quarter window & on the roof just behind the front windscreen
aircon needs a regas, was working fine until it ran out & i left it planning on the engine swap
central locking plays up, but the car can always be locked
alarm isnt making noise, but the immobilisers still work fine
passenger window isn't currently working, i believe due to the alarm auto-window lift malfunctioning. if you put power on the motor inside the door the window operates fine, & the switches are working fine also.
Located in western sydney close to minchinbury
Asking $7500, NO SWAPS PLEASE, i already have WAY too many toys.
OR
Price with included extras $13,000.
Extras
RB26DETT (N1 turbos, gates timing belt & modified RWD sump approx 9 litre capacity just fitted)
RB25 box & custom 1 piece driveshaft
PowerFC (& hand controller but unsure if it suits GTR, purchased separately & not tested)
Link to pics: http://s979.photobucket.com/user/cmoney9630/library/R32%20GTS-T?page=1
Any other pics you want that aren't already there, let me know as I may have some floating around.
PLEASE NOTE: extras are NOT for sale separately unless the car gets sold on its own first, thank you.
Best contact on here via PM, or 0407 896 339.
Cheers
Chris
Edited by cmoney
https://www.sau.com.au/forums/topic/423070-r32-gts-t-nsw-plenty-of-mods/
  • 1 month later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
