Hey guys, so ive had a TPS issue with my r34 (fault code checked and confirmed) and after a period of driving, the cars idle and engine operation become erratic. The car then began not starting, i figured it was due to the tps. Replace the tps and the car still has a problem with not starting. When i press the accelarator down while the engine is not on I get a loud buzzing sound from deep in the engine bay, as if it is near the trans. I do have fuel pressure, not sure on spark but the buzzing is giving me concern.
Anyone had this issue?
https://www.sau.com.au/forums/topic/423075-rb25de-neo-not-starting/
the buzzing is because your tps is out of adjustment; you can turn your ignition to on- loosen off the screws on the tps and move it around till the buzzing stops then retighten the screws; car should then start
Thanks bud, but its not the tps, its deep down, like near the transmission. Not sure if its a solenoid or what. It only buzzes when the throttle is more than idle. There seems to be spark or there would be a code thrown up when I check the fault codes, but I get code 55.
no doubt the noise is low down but ive had the EXACT same problem on my auto 32 and the EXACT same buzzing sound and itcame from down near the trans, as soon as i had adjusted the tps it stopped
You were correct on the buzzing sounds from the tps. I adjusted the tps and the buzzing did occur in the same place, although for some reason it has not solved my problem....
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
