Apexi Power Fc With Hc $800
I shouldve mentioned that the engine is near being complete. I double checked with my mechanic but im pretty sure the machine shop did all the nessecary checks on the block. i also won’t be driving on 800 all the doing doong pulls. Mainly be driving and cruising with friends on low boost maps occasionally opening everything it’s got.
Should be close enough. Noting that 88Nm is equivalent to 2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there.
Cant find a torque spec in the R32 gtr manual But there is one in the silvia manual Not sure if it's the same
They care about emissions, and cost the most. Save weight where possible, and make manufacturing easier. Less material also let's the engine transfer heat to water quicker, and bring the engine up to temp quicker, better for emissions and getting them past their warranty period.
