The Fmic that I have has press bends on the piping.
It isn't like bad press bends it is hardly noticible.
If I'm KW chasing do you think it is worth buying 4 90 degree bend mandrels (3 on inlet, 2 on outlet)?
Or would this only help with boost response and lag?
Lag is hardly noticible now with the EBC but it is still there..
I had a look at some of those silicon bends and i think this smiley says it all
:eek::eek: :eek: :eek:
https://www.sau.com.au/forums/topic/4231-press-bends-on-fmic/
hehe yer..
Turbo fund that keeps getting spent on other things.. :)
Almost had all of the money then i went and upgraded the comp now i'm getting close again and i'm starting to think about suspension.
I'm waiting from a few ppls on a $$ for the GT25 400hp..
Actually on that topic i went to Turbo Tune in Adelaide and they seem to think the GT25 400HP will flow enough to make a good 180rwkw.. I said what.. 180rwkw.. I want more than that.
hrmm.. All i want is to be able to overpower grip in second gear any time.. :burnout: :burnout: :burnout: :burnout:
https://www.sau.com.au/forums/topic/4231-press-bends-on-fmic/#findComment-67715
Same... I'd like to nudge over the 200rwkw mark and POssibly be able to run high 12's with a lowish tyre pressure if need be using the 225'50's.
The Simex that I run at the moment give unbelievable grip.
First gear hardly spins up.. but if i click second a little to quick she still tries to snaky second.
I might be pushing it though I figure that if whatsisname can run 13.1 1/4 2.1 60ft using 216rwkw I should be able to do it with a slightly better 60ft time and a little less power due to less weight.
I hope.
I thought a little about a VG30 turbo as that can get damn close to 200rwkw with adj. cam gears etc BUT.. Reliability of the turbo comes to mind as at the moment I can't afford to waste 500 on a turbo that blows up later on down the track.
Also everywhere i go they say to inspect the turbo as if it is a dud they wont exhange/return it. :) That is the Killer..
I need the turbo to have no problems as I'm going to uni for the next couple of years.. I defered this year...
Tim has suggested that the GT25 that he is able to get which is $1400 will just make 200rwkw with it running out of breath a little up top. but 200rwkw is 200rwkw.
I've got him looking in to a slightly bigger gt25 which should make just over 200rwkw which then i will be happy.. well on paper at least :D
https://www.sau.com.au/forums/topic/4231-press-bends-on-fmic/#findComment-67723
Your Avtar looks nice..
Its a very nice looking 32 Adam.. :)
I'm waiting to see how Clint32's Turns out. :)
Hopefully he doesn't take tooooo long :D
The T04e is an option apart from the fact of having to buy a wastegate etc.. which bumps the price closer and closer to a new turbo that bolts on with an adapter plate..
hrmm.. If it turns out good though i might look at it.
also how have you got 100 more posts than my self.
I log on every day post like crazy (don't post whore but) and still 100 behind you.. :)
https://www.sau.com.au/forums/topic/4231-press-bends-on-fmic/#findComment-67732
haha i dunno
i havent checked how many posts ive got! yeh i dont write too much crap
well you can see how my project turns out as well. im waiting for a winning lotto ticket so i can get a remap. hopefully by then the car will be running well (ie leaner that 10:1) and may make some decent power!
ill keep you posted though!
https://www.sau.com.au/forums/topic/4231-press-bends-on-fmic/#findComment-67903
