Hi guys,
I posted this in nsw thread in reply to something else but thought here is a better place. Just went to install gearbox onto new engine that has rear oil drain and twin plate clutch. On previous installs I usually angle engine down so gearbox can be attached but with the rear oil drain so close to my freshly painted engine bay I'm pretty sure it will hit. The only option I can think is lift engine off mount which isn't an issue as its just sitting there nothing hooked up, and move it forward then connect box and move both back or is there another truck in missing? I've searched a fair bit on the web and sau and can't find the answer.
Scott
https://www.sau.com.au/forums/topic/423102-r32-gtr-gearbox-install-problem/
Maybe it's a strength thing Duncan do u have any time free this week? Jez suggested lowering engine cross member which sounds like it could help but definitely with the wife and myself there wasn't enough man power to twist and maneuver that's for sure
I like to take a bit of material off the ribbing on the starter motor bump to get a little more room. After that its just some brutality to get it in. Are the clutch plate splines aligned?
when we do them, we spin 4 8mm nut's onto the engine cross member studs, and undo the engine cross member nut's, and they bottom out on the 8mm nut's.
drops the engine down about 30mm, makes a huge diffrence.
Cheers
I will have a look at that but I just had a look a there is no room to angle engine without hitting firewall so box must go on straight. As the engine is just sitting there if the cross member idea doesn't work I'm thinking moving the engine forward should do the trick .
My dad gave me a hand with the engine forward all the bolts were so easy, a little mucking around to line up engine mounts after box was attached but still less than an hour so I'm pretty pleased its in, now to all those pesky fabrication mods
    • Let's face it. 90s turbo 6 with 80s tech in it is not going to be the thing that runs as clean as a whistle.
    • No. See below. No. In the specific case of Enthusiast, the wording in the PDS says, explicitly, " We will not pay any claim on a Vehicle with any Modifications not agreed by us and not listed in the Schedule. This includes any Modifications or the fitting of a device that contravenes the requirements of the Australian Design Rules [ADRs] or where allowed, the Australian Vehicle Standards Rules [AVSR]." The 2nd paragraph needs to be read in a different tone of voice from the 1st. The two concepts are connected, but they are two different concepts. The 1st says your mods must be listed and agreed with us. The 2nd effectively says "we won't pay if any mods are not legal". The way that it has been written in more general insurances for a long time has been that if the mod contributes to the accident then you're shit out of luck, but if the mod didn't contribute, then you'll probably get away with it. With "probably" being a very flexible term, and being an insurance company, better left untested than hoped on!
    • I'm not surprised, I favour a bit of a richer tune which for sure isn't helping the emission numbers.
    • Overboosting is more likely a function of whatever boost controller you are using than the actuator. "Overboosting" is a feature of cheap boost tee type control. If you don't want to see peaks of overboost, you have to set it to not produce them. And that then means you don't run as much boost as you might like elsewhere. That's just life. Electronic boost controllers can generally be set to do a much better job of managing the peak boost.
    • Had a good chuckle because it is listing THC g/km. Though it is not tetrahydrocannabinol but total hydrocarbons. Interesting how the numbers seem so much worse compared to Greg's big V8.
