Lower Control Arms - SOLD
Heater Core - SOLD
Stock Suspension - SOLD
Handbrake Gear boot - SOLD
Window Weather Shields - SOLD
Center console - SOLD
Windscreen wiper washer bottle - SOLD
Nissan Sumitomo S2 ABS brakes complete 4/2 pot front/rear (hubs, brakes & brake pads, discs etc...) - SOLD
Front Guards $150 - SOLD
Nismo Clear Side Indicators -SOLD
Genuine S2 Front Bumper inc. Factory M-Spec Front Lip & Indicators - SOLD
HICAS - SOLD
Stock Rims - SOLD
Airbox Snorkle - SOLD
Front Grille - SOLD
Front engine strut till up? Good condition? Pic? Dibs if good nic.
Hi Tyson the car didn't come with a front strut brace. I have a good condition factory adjustable rear strut brace if your interested $100
Still got the fuel cradle, tank lid and level sensor?
Fuel cradle unavailable
Tank lid $20
level sensor $50
Edited by DarkRyda
  • Replies 140
Heater Core - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
Steering Rack - SOLD
Do you have Steering rack and cross member?
Steering rack has been sold
I have lots of interior parts left pretty much everything price negotiable on some items need to get rid of the interior!
Heater Core - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
3" Fujitsubo Giken Cat Back Exhaust - SOLD
Seat Belts (Front / Rear) - SOLD
Heater Core - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
S2 RB25DET Auto ECU - SOLD
Hey mate do you still have the stock cooler piping?
Hi, no sorry i don't =)
Anyone interested in a full interior? willing to seperate let me know what you need i have a full R33 S2 interior off this car, pretty much all parts available, dash, cluster, seats, door trims, carpet etc...
Edited by DarkRyda
Heater Core - SOLD
HICAS - SOLD
Stock Rims - SOLD
Front Grille - SOLD
Subframe - SOLD
S2 Spoiler - SOLD
Auto Diff - SOLD
Driveshafts - SOLD
Passenger Side Door - SOLD
Factory Adjustable Rear Strut Brace - SOLD
Hi mate,
Do you still have the lhs quarter glass for sale?
Are you able to post to qld or is everything pickup only?
Thanks
Jamie
Edited by «Cyph3r»
Hi mate,
Thanks
Jamie
Hi mate sorry cant post it. The glass is fragile, it might break via transit id rather pickup so people can inspect the items before paying me.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
