Hey all,
My drivers door lock barrel has always been a little loose but lately has gotten to the point that it has twisted the plastic cover off the top.
I imagine that there would be a simple clip to secure the barrel to the door or similar.
If anyone has come across similar problems and can let me know before I start taking the door apart.
-Luke
https://www.sau.com.au/forums/topic/423124-door-lock-barrel-loose/
The door lock mechanism is held by two bolts but to get to them you need to remove door inner liner and the door window glass. Its been a few years since I put my lock cylinder in but from memory I don't think you can access it without removing the window glass. A bit fiddly but not that difficult. The lock cylinder can only be removed /tightened from the inside. Good luck
