RB30 bottom end
It was a running engine and it's an R31 version so has the oil drain plug thingy for turbo-ing it. Also have a box of all the ancillary that goes with it: alternator, starter-motor, power-steering pump etc. It also has brand new ARP head studs $300 ono
R32 GTR head, plenum, ITB set-up etc with RB-25 cam covers. Also has tomei cam studs cam-caps etc all boxed up
no cams there sold $1,000 ono
head and block are currently bolted together so will do a package deal if you like
Chinese-spec T70 turbo with manifold and external gate to suit RB25. Good condition $300
HKS/gts-r ? RB25/20 low-mount external gate manifold came with a HKS TO4R kit I got off yahoo its T4 flanged $1,200ono
had a fabricator mate check out the manifold and the external gate pipe which is twin exist into the flange is not a add on
from his opinon meaning it was made all at the same time (TURBO IS NOT FOR SALE)
RB25 NEO specific Tomei Cams 260 / 9.15 in + ex done around 500kms before getting defected and were bought brand new for $1,550 These are cams. $600 ono
pm's welcome
041 1152 seven three three
  • 3 weeks later...
I would do there 10mm rb26 ones bloke told me they cost him $350 new and weren't torqued up
to fitted to dummy the head make a offer
ahh shit i need 25 ones mate
  • 5 months later...
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
