Hey guys,
I have come to a deliberation with my pride and joy. It only has basic bolt on mods & wheels. (pic below).
My question to you is... do you think I would get more for the car overall if I sold off the mods, and then sold the car stock? Or just sell it as it stands. More attractive to buyers with or without mods do you think?
Edited by samdasurfinman
https://www.sau.com.au/forums/topic/423196-to-sell-with-mods-or-stock/
I was in the same boat as you not long ago (get it? Cos the R33 is considered a boat? Get it? Get it?) and in the end, I sold it complete.
You would probably get more $$$ out of it if you were to part it out (and being basic bolt-ons, could be easy enough to do in your spare time) and sell it near enough to stock. I didn't have that option as the car would've required ALOT of stock parts and I just didn't have the time to do so.
I guess if you've got time (and don't mind delaying the sale), then part it out till it's almost stock. If you're after a quick sale, just sell it as it is :)
If they're just "basic" like exhaust, FMIC, pod filter, bleed valve etc it's probably best to leave it as-is, but if you have an aftermarket turbo, injectors, ECU, coilovers etc you should probably get more $$ selling it stock
Not trying to sound smug.
It's an R33 sedan - The interest on them is quite low - they are the most un-desired 4 door skyline IMHO.
If you want to move it fast, sell it with everything, but if you are happy to wait and have the stock parts - I'd sell the good bits separate.
I agree... It all depends on how motivated you are to sell quickly or not.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
