Intake done in December. I think the ping was before the intakes went in.
Even if it was after...wouldnt the ECU be picking up the different intake and adjust accordingly? I reset the ECU a couple of times since then.
Ping only at low revs...1.8k to 2.3k? higher revs/speeds no ping.
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6809879
Nope, have not changed spark plugs/fuel pump at all.
Got the car Nov 2012. Car is a 2007 V36. Got it with 36k kms on the clock.
I'll try United P100 and see what happens. Will try to clean MAF and throttle body on the weekend and proceed to spark plugs and fuel pump if all fails...
Is there anything I am missing? Should I try stock air intakes?
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6809912
Maybe try running some Subaru upper engine cleaner through it? Get rid of some gunk built up in there (and give you a nice clean intake manifold while you are at it - might not fix it, but for under $20 it is worth a try) My V35 ran beautifully afterwards
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6810137
It also depends on where you bought it as to whether it really has 36k on the clock - it costs under $100 to get this changed. If you have more km on the clock, there are other things that could be more built up in the engine or things that could be wrong. Obviously at 36k it should be basically a brand new car ...
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6810198
Ok ill try checking the AFM and the cleaner. I dump in Nulon Fuel System Cleaner and 44l of P100 last night. Lets see what happens over the next few days.
I bought the car on auction from Japan. It was checked for genuine KMs by computer system. Whether or not it's genuine, can't really be that sure but yes essentially the whole car looks brand new and nothing was modded or been touched.
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6810623
Could the the timing yes, one of the more common causes...
Mine has zero mods, its just my daily and I haven't had it for long, but being a high comp engine with Japanese ecu tuning I'm not hugely surprised by the ping on crappier fuel. But I will look at spark plugs and intake clean soon
The Mirage on the other hand has been driving me nuts. I have changed the plugs, plug leads, dizzy cap, rotor, fuel filter, air filter, checked the timing, three rounds of intake cleaning (two at home and one with a pro machine) and full bench injector clean with new o rings etc... yet, still pings :rolleyes:
Next step - colder plugs and oxy sensor. No luck with cheap OBD2 adaptor either
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6813062
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
