Dude there is definitely something seriously wrong with your car. It should not ping. Ever. The ECU is smart enough to prevent detonation and retard timing a long time before you can hear pinging. My V35 makes 183rwkw and I drive it like I stole it, and it NEVER pings. I have an ear for it (my R34 used to ping depending on boost and fuel used).
Get a mechanic to check it out asap - at least get it on a dyno to check your afrs.
https://www.sau.com.au/forums/topic/423199-ping/page/2/#findComment-6813066
I disagree. The ecu isn't that smart. You will hear the rattle a long time before the ecu drops into high det mode. In fact motors have been lost cause the ecu hasn't dropped into hi det.
Take your car to Nissan, and get them to plug it into consult. Your mechanics obd reader sounds shit. Ask them what the timing is set on, and if you can get them to check the ign timing is right. Should be 15 degrees at idle, at least that's for a DE. They can adjust static timing, and t might be worth getting them to reduce it.
https://www.sau.com.au/forums/topic/423199-ping/page/2/#findComment-6813104
But how on earth would a 36k old engine be detonating? Like I said mine has been running 183rwkw and has now done 125,000km and I even drive it hard on the track and can't even hear it rattle EVER - it runs like a dream (admittedly I do have a bigger oil cooler, big alloy radiator and an oil cooler, but still). Let alone at low revs like the OP is stating.
https://www.sau.com.au/forums/topic/423199-ping/page/2/#findComment-6813145
While being very dubious about any import being 36k Kms old, I'll let it slide because Kms has nothing to do with knock. Ping is most likely to occur in the peak torque range of the motor. That's why when you look at an ign map, through the mid range timing advance decreases and gets returned higher in the rev range.
As I said. Too much ign advance and or poor quality fuels, or fuel starvation. It needs to be put on consult and read as to what it's actually doing. Even stock Ecus have static timing adjustment which means you could make it ping.
https://www.sau.com.au/forums/topic/423199-ping/page/2/#findComment-6813150
Have you changed the plugs recently?
I would have a guess and say you have a slightly blocked injector, or you're fuel pump is faulty. Have you changed the fuel pump?
If the intakes are leaking after the afm's it will cause it to run lean...
QFT.
https://www.sau.com.au/forums/topic/423199-ping/page/2/#findComment-6813153
Yeah, I was not sure how to adjust the timing of the ECU using the OBD 2 scanner. I was told I should be able to change certain values on the ECU using the OBD 2. Was using my uncle's one, he owns an auto shop. I didn't know how to so I left it alone. Might go back and try it out later on again.
And yea my mechanic works at Nissan, am trying to book my car in so he can do it. I only went and test it out myself cause I couldnt get a hold of him as yet. And since my uncle has the tools I thought I'd give it a go :) too bad he doesn't have Consult III, he has the universal one for different car brands. Was quite impressed it worked on the V. Then again for the amount of $ he spent on it, it should have worked.
Edited by colin.ssc
https://www.sau.com.au/forums/topic/423199-ping/page/2/#findComment-6813467
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
