Hi All,
Im looking at changing my HFC and y-pipe with some aftermarket ones. I know the G35 and V35 are basically the same car but I just want to check that the exhausts are the same before I purchase some parts. Im looking at:
- M2 2.5" Y Pipe (Based off the HR Design) (linky)
- Kinetix HFC (http://www.autocarparts.com/part/1453/0/)
Will this all bolt up to the rest of the exhaust? Also does anyone know a good place to have this done in Perth?
Thanks guys!
https://www.sau.com.au/forums/topic/423212-v35-y-pipe-hfc/
Steer clear of cheap Y-pipes! they are made of crappy thin steel and rust quickly;
I'm getting my cheap ebay one replaced with a custom one when I get generic high flow cat's fitted (I can get the CEL disabled in Uprev; so I'm not concerned about the CEL)
Might work out cheaper for you to think about that way anyway; by the time you buy two generic 2.5 inch cats (300ish), pay some money to get one custom made (I've been told around 200-250) to fit), and then Get Uprev... you are still cheaper than paying 500 for a Y-pipe and 500 for a set of HFCs, and your car is faster coz it's been tuned :P
Or you could do what the Americans do and fit spark arrestors and avoid the tune; but where is the fun in that
https://www.sau.com.au/forums/topic/423212-v35-y-pipe-hfc/#findComment-6810118
I bought the Kinetix hfcs, and the passenger side one fouled under the car near where it connects to the y-pipe. Had to pay an exhaust shop about $100 to stuff around with it - which was the difference in price between some better brand ones that I should have gotten in the first place. And the guts of one of the hfcs came out within 40,000km. So I do not recommend them.
https://www.sau.com.au/forums/topic/423212-v35-y-pipe-hfc/#findComment-6810277
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
