There Is A Hole In My Hub Assembly With A O Ring On It (Pics). What Goes In There? Need Answer By Tmw
That is where the senser for the ABS attaches to.
I have simply made up a plate to cover the hole and attached it wth a bolt to keep it in place.
Thanks for the info.
I got these to replace my parts, a direct swap, they are of a 96 gts-t, but my car, also a gts-t has no abs.
Can they still be fitted without problems?
Does that hole lead to the bearings? I want to pour some lubricant in in there. Not made for bearings but for bike chains etc. it has mos2 in it and i find it works well.
Edited by sonicz
The sensor points at a slotted wheel which you can see when you look down the hole. The bearings will be behind seals so i think you'd just make a mess if you pour lube down there.
