hey guys this build is starting to drive me crazy, im finding so many different opinions on what should be done to build a decent rb30det, i have just aquired a low k rb 30, now my plans at this stage are to fit it with acl race bearings and a decent set of rings but retain the factory na bottom end, i am a qualified mechanic so that is no issue building that... i have a 25det head which i am in the process of getting its cleaned up and freshened (recut valves, new stem seals weld vct feed etc) what i would like clarification on is what i can expect out of this setup with say a gt35r, nistune ecu, injectors to suit, decent cooler, crank collar with 25det pump and what ever else i have forgotten, bare in mind i am only a mechanic so my budget is by no means huge haha. id be absolutely stoked with a reliable 250+rwkw, and inputs would be greatly appreciated cheers guys
  • Like 1
https://www.sau.com.au/forums/topic/423229-stock-bottom-end-rb30det/
Just above your post
Here is the thread: http://www.skylinesaustralia.com/forums/topic/15420-r33-rb30-conversion/
here is the pdf in that thread:http://stevenwelsh.site.net.au/RB30_DOHC.pdf
here is the RB30 turbo upgrade thread: http://www.skylinesaustralia.com/forums/topic/104332-rb30-hybrid-upgrade-all-dyno-results/
im a bit of a forum newb how do i locate said threads?? cheers
to be honest i wouldnt even bother doing rings and bearings if the rb30 you have is a good condition running engine.
for example.. my rb26/30 is stock as a rock only things i have done is oil restrictors, shimmed up oil pump and rb25 sump. MLS headgasket and ARP studs hold it all together.
i make 395 rwkw and the car is a drift car and has been going for ages like that. running e85 and 35R turbo.
  • Like 1
holy crap, well i guess that could be money better spent on other things cheers guys, what advantage does a rb25 sump give u as i have one spare, shimmed up your rb25 or 30 oil pump?? what oil restrictors would u recommend, im planning on running external vct feed, thanks heaps guys!!
25 sump has two windage walls on the back of the sump. needs to be ground to clear the crank. other then that its the same.
block off the front feed and put a 1.5mm restrictor in the rear. run the VCT feed as per the guide but make sure that it also has restrictor.
i just shimmed the 30E pump
yeah just the rear part... its pretty strasight forward when you go to fit the sump to the block and turn the crank over.. it fouls
i run a P1000 haltech
haltech would be awesome to run!!!i just pulled the head off my 135,000 k bottem end and its as clean as a whistle, but i did find oil in the intake pipe so might have a bit of blow by so it may require a reco, what kind of revs does urs pull mate??
yeh i dont wanna rev mine too hard as it will still get street driven, and i wanna keep it reliable so id like about 300rwkw at the most, but it seems im gunna have to freshen this bottem end up unfortunately..... can u boys recommend a decent computer to run that doesnt require an afm and wont cost me a gazillion bucks
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
