BOV's are not as bad as cops make out, yes they vent but its only air not exhaust gas, if I get pulled up I can see I'm going to be arrested for telling a cop he's a dumb shit (being a mechanic)
I hate that they can hand out defects for things they don't even know the name of.
wut?
you are correct that they only vent air
but they affect the afrs (ecu adds fuel for the air that it thinks went in)
therefore resulting in too many bad gasses which kill baby seals and rape pandas
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6857381
wut?
We can't have our cars raping pandas now can we?
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6858286
My car got defected for one dead numberplate light... Cops will pin you if they want to, unfortunately you can't stop them.
My new build im using a bov that vents to atmo cos I don't want any pipes into my intake lol, same as my catch can won't plumb into intake.
If I ever get a yellow for the bov I'll just blank it for the inspection ;p
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862073
Run the catch can pipe into the airbox? Doesnt need to feed into the intake pipe then!
Atmo BOV is just asking to be hassled though!
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862086
gate impresses slarts not bov!
neither you would understand hence why ur gay!
All I have to do is start my car to impress, I don't have to hoon or hit boost or anything. Simply changing gear at 50ks at half throttle will literally knock the sunglasses off the top of your head ;)
.... Anyway woooosh noises are cool, I'd have a woosh noise if I had a turbo
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862336
oh thats right coz your car chirps 3rd! :rofl:
https://www.sau.com.au/forums/topic/423242-defects/page/2/#findComment-6862347
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
    • Put a piece of tape on it.   If it's that gone, you would be seeing it on the balancer. It would look rooted. Not in this universe.
