Up for sale my much loved 32 great car.
1993 R32GTS-4 Series 2 RB25det 115,00kms on engine 160,000kms on car Full GTR Running gear HSD HR Series Coilover F8KG Rear6KG Whiteline Hicas lockout bar Whiteline front strut brace JJR rear strut brace KKR Rear adjustable camber arms R33 GTR wheels 17x9 +30 with maxxis 235/45/17 tyres 90% tread R32 GTR Front and rear brakes with bendix ultimate pads GTR Style front bar, GTR Skirts, rear pods and wing Front and rear GTR seats all in very good condition, autometer cobalt series boost gauge, Clarion head unit, front speakers with kenwood rears. Vipec ECU Garrett GTX3076 .82 rear housing hpc coated by croyden raciing developments with custom oil drain all teflon lines and pro flo fittings Turbosmart Progate 50mm external wastegate with screamer Capel Motorsport steampipe manifold also hpc coated Custom stainless 3inch dump pipe hpc coated, into high flow cat to 3inch stainless catback Extreme Stage 2 Clutch Jecs 750cc Injectors Bosch 040 Fuel Pump JJR Forward facing plenum 90mm JJR throttlebody Splitfire Coilpacks 4inch intake with inch drift filter Clear Timing Cover Gates timing belt JJR front mount intercooler with capelmotorsport piping Custom Oil catch can Oil Cooler with foil filter relocation kit JJR Alloy radiator Made 300RWKw with old turbo setup only been road tuned with the GTX3076 so far but would still be making 260-280kw. 300kw easily reached with a few hours on a dyno. Really nice R32, GTR atessa 4wd system. Only selling because i hardly use it and money could be used for other commitments. Much loved car.Only thing it wont be sold with JAP032 Plates they were a gift. Fully owned car no debt on it. Feel free to shoot me a text or call if you have any questions.
$15,000ono
0487 480 099post-63953-0-61933800-1365558147_thumb.jpgpost-63953-0-65915300-1365558165_thumb.jpgpost-63953-0-77029000-1365558201_thumb.jpg
https://www.sau.com.au/forums/topic/423259-fs-1993-r32gts-4-rb25/
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
