was intrested in know the first signs of a clutch shitting itself.
the other nite i was at a mates workshop n pulled a nice burnout, but when i changed in second there was major slippage! i took my foot of the accelerator 4 a sec then put it back on n still it was slipping, anyways when i got home it stunk so bad, (not the normal clutch smell) 10x worse.
when driving normally theres no problem, but when i boot it, it feels a lil slower than it should b goin at higher revs,
also when i down gear into 2nd doin round 50km/h i can smell the clutch again.
is my clutch on its way out?
should i start saving 4 another?
or do i still have a while b4 it will need changing?
thanks in advance
john
https://www.sau.com.au/forums/topic/42327-clutch-issues/
smells like fish when frying the clutch.
You can tell if you drive at like 60k's, put it in 5th gear and floor it. If the revs jump but speed doesn't, then you're in trouble. if not you could be aight for a while.
Also, rev the car up to like 5000-5500 before changing and see if the revs jump up then settle back down. If they do jump up, then its slipping.
https://www.sau.com.au/forums/topic/42327-clutch-issues/#findComment-865211
Yeah I had the same thing, it felt a little funny on the way to work (~40km), and I almost didn't make it home... It happened as got a near perfect launch the previous day, and burnt the stock clutch from excess slippage on take off. The was still a bit of meat on the clutch, but I had glazed it so bad, there was barely any friction.
My advice is NOT to accelerate hard under any circumstances to prolong it until you have a chance to change it, otherwise your car will soon be undriveable...
https://www.sau.com.au/forums/topic/42327-clutch-issues/#findComment-867428
mate the same thing happened to me once, what i think you have done is glazed the surface of your clutch...u might still have a fair bit on it but you will need to change it sooner or later... Soon after that happened in the mornings the clutch would shudder a bit untill it warmed up, you will have a month or so of use, but it will start pissing you off soon so an exedy single plate is a good idea...
https://www.sau.com.au/forums/topic/42327-clutch-issues/#findComment-874395
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
