CLEARING OUT EVERYTHING, ALL PARTS FOR SALE :)
Located in Western Suburbs of Melb
Contact me on
0432 544 363
SILVIA PARTS (yes i know its sau)
S15 SR20det exedy hd clutch with mad flywheel $450
S15 SR20det complete loom $150
S15 SR20det complete intake manifold, injectors etc $250
S15 ADM headlights $300
SKYLINE PARTS
RB26 bare head complete with cams & valves no rocker covers $600
RB26 (R32/R33) Mine's pod filters with elbows $150
RB26 front pipe mild steel $50
RB26 standard turbos suit rebuild $100
RB26 harmonic balancer $50
R33 GTR midnight purple doors $150 each minus trims
R33 gtst series 1 loom & ecu $150
R33 front seat belts, drivers side has the holder thingy $50
R33 centre console glovebox $20 x2
R33 GTR nismo 320kmh cluster and centre triple gauges $500
R34 hubs and uprights 5 stud $150
R34 doors complete minus mirrors $100 each
R34 Boot $50
R34 headlights one tab broken $500 pair
R34 RH tail light $20
R34 aftermarket taillights $100
R34 GT-T & R33 GTR pull type clutch $400 x2 to choose from
Everything is still up for sale except for
R34 Headlights
S15 Headlights
Few extra items added to the list
(for these 4 items, message 0430 836 049 - other items, message the number states in the add)
R34 GTV Suede Front Seats - $150 for both
R34 GTV Suede Rear Seats - $40 for both top and bottom
R34 GTT SII LSD DIFF - $400 (PRICE NEG)
R34 INTERIOR REAR DOOR TRIMS - $30
Price drop
R34 front seats - $120 for both
R34 rear seats - $30
R34 front seat belts- $30 for both
R34 rear door trims - $20 for both
R34 GTT S2 LSD diff - $300
Also selling a stock turbo rb25 manifold -$100
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
