If you have the dreaded creaks in your front end this could be the solution. Be sure to eliminate any other possibilities first.
:excl: Before you start this you must try to get the lower bearing. :excl:
It is hard to find, Nissan will make one for $150, and the dust seal is $120, so try and save the seals.
Be safe, use stands and a good jack.
You need a breaker bar, a 14, two 17s, a 19, a flathead screwdriver or two (one strong and one sharp).
Take off the front wheels
A bit of wd to loosen things up.
Pop off the brake line clips, just these two is enough.
Undo the nut on top of the swaybar link. Take off the washer and rubber.
Take the sharp screwdriver and carefully pry off the dustcap.
Undo the nut and take off the washer too.
Out it comes. Dont forget a block of wood!
Undo the nut at the bottom of the strut. Take it off the arm.
Undo the nut and bolt on the outside of the upper arm.
Push the arm down to get the bolt out
All gone.
Always clean parts, especially if you are taking them to a workshop.
Rust!
Remove, etch prime, paint.
post-89755-0-72181500-1365659305_thumb.jpgpost-89755-0-54599000-1365659333_thumb.jpgpost-89755-0-93310200-1365659353_thumb.jpg
Now you can take it to get the bearings pressed out, and the new ones in.
Putting it back together is easy, just do it all in reverse, and dont forget to grease the new bearings, use plenty.
Thats pretty easy, its only a few nuts and bolts, the hard part is getting the bearings and seals.
Torque settings: Foot pounds.
Kingpin nut. 72-87
Lower strut nut. 80-94
Outside upper arm nut and bolt. 65-80
Swaybar link. No data for gtst. GTR is 30-35
  • Like 1
  • 3 weeks later...
The guy at Nissan gave me trade price i think, the bearings cost $250 for the pair. 2 weeks wait, lucky it wasnt 4.
The upper bearings are $8 each.
Pressing cost me $100, the lower bearings arent easy to get out, they had to weld the bearing together to get it out.
  • 3 years later...
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
