i had a gtx3076 in 0.82 external gate form and it was a little dissapointing how late the rush came on 98 fuel, even with E85 it was a doughy unless the revs were at 4000rpm onwards where it would react with massive wheelspin ( setup dependent).
I dont know if an OP6 housing would flow as much as a garrett so it might have better response but then choke up top,
you'd be better off with a GT3076 with a Garrett 0.63 or 0.82
Edited by AngryRBGTX
https://www.sau.com.au/forums/topic/423351-gtx3076/#findComment-6812792
I think its going to cook the OP6 rear housing tho. that comp wheel is good to run on external gate with a .82 turbine housing. If you have to use that OP6 rear housing with a GTX core then chose the gtx3071
https://www.sau.com.au/forums/topic/423351-gtx3076/#findComment-6812874
GTX3071 for the win! Better response and better comp to turbine ratio.
Yep, steer clear of the GTX3076 for low boost/power combos as from what i can see its better suited to someone looking for a GT3582 type result :)
Mick_o set the bar for the GTX3071 and it seems to be a hell of a street combo!
https://www.sau.com.au/forums/topic/423351-gtx3076/#findComment-6813273
Apologies that I don't follow these threads too closely - what is the general consensus on the OP6 housing allowing in terms of flow? I would be surprised if it would even allow a GTX3071R to be utilised properly. Is this case one where a GTX3067R might be worth considering?
https://www.sau.com.au/forums/topic/423351-gtx3076/#findComment-6813283
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
