Hi there,
I have the Cyclops P385T installed in my car. Recently the central locking has started to play up.
It's not working properly anymore, and I'm trying to work out what is wrong.
Firstly, the car battery is fully charged, and the batteries in the remotes are new.
The main button on the remotes does not automatically lock and unlock the doors when pressed.
Central locking will only work if I manually use the key on the drivers side door to either lock or unlock.
Is there anything I can do to fix this issue?
I should add, the car was disconnected from the car battery for about 6 months. Not sure if this may have something to do with it?
Thank you for your help.
You could start by removing the door panel and checking the door rod connections on the slave motor....if it has one installed as not sure what car you have.
I have a Nissan Cefiro.
I have taken off the panels, had a good look at all those rod connections, and everything looks connected up properly...
The central locking does actually work, but not by the push of the main button on the remotes.
Central locking will only work by manually inserting the key into the drivers side door keyhole and turning to lock or unlock.
If turned to lock, all four doors will lock, similarly for unlock.
So the problem is: central locking just won't work from the main button on my two remotes. It's like central locking has somehow been turned off from the remote.
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
