Parts off my car for sale.
Apexi Power FC L Jetro for R34 GTR = 1000 ONO pick up or posted
R32 Air Flow Meters x 2 = $50 each pick up or posted at buyers expense
RB26 Rubber intake pipes = $80 pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = $300 pick up only
Non genuine Sard Fuel Pressure Regulator (Came with the car and only found out after taking it out) = $50 pick up or posted at buyers expense
Willing to combine the Greddy fuel rail and pressure regulator if someone wants as a package.
Items located in Liverpool NSW.
PM if interested.
For some reason SAU won't let me attach pics, will try again tomorrow.
I can also send pics via mobile if needed.
Cheers,
Will
still got the computer for sale? I am looking for a power fc to suit R33 GTR. Am located in Liverpool
Power FC is still available, though i don't think it will work on an R33 GTR.
Fortunately for you i do have mate whos thinking of selling his Power FC from his R33 GTR Vspec.
PM me if your interested
Apexi Power FC L Jetro for R34 GTR = PRICE DROP $900 ONO pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = PRICE DROP $250 pick up only
Hi Guys
Just an update, it turns out my SARD fuel pressure regulator is Genuine, thanks to a forum member enquiry i double checked it.
The website i used is linked below:
http://www.silviawa.com/forums/index.php?showtopic=39446
Point 2 confirms that mine is genuine, see pic in the first post.
I will be bumping the price up to $150
Apexi Power FC L Jetro for R34 GTR = $900 ONO pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = $250 pick up only
Genuine Sard Fuel Pressure Regulator = $150 pick up or posted at buyers expense
Apexi Power FC L Jetro for R34 GTR = PRICE DROP $850 ONO pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = PRICE DROP $200 pick up only
Apexi Power FC L Jetro for R34 GTR = FINAL PRICE DROP $700 FIRM pick up or posted at buyers expense
R32 Air Flow Meters x 2 = FINAL PRICE DROP $20 FIRM each pick up or posted at buyers expense
RB26 Rubber intake pipes = FINAL PRICE DROP $50 FIRM pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = FINAL PRICE DROP $150 FIRM pick up only
Genuine Sard Fuel Pressure Regulator = FINAL PRICE DROP $100 FIRM pick up or posted at buyers expense
Apexi Power FC L Jetro for R34 GTR = $700 FIRM pick up or posted at buyers expense
R32 Air Flow Meters x 2 = $20 FIRM each pick up or posted at buyers expense
RB26 Rubber intake pipes = $50 FIRM pick up or posted at buyers expense
Greddy Fuel Rail with nuts, bolts and hoses = $150 FIRM pick up only
Genuine Sard Fuel Pressure Regulator = $100 FIRM pick up or posted at buyers expense
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
