What type of clutch are you using? Stock, yes, your clutch is getting worn. Aftermarkets like Twin Plates and Super Singles and such naturally bite quickly, but a stock clutch should be almost as soft as a cushioned ceramic. Under what circumstances does it shudder? What load/rpm/gear range?
best way to tell if its on the way out is put it in a high gear at low speed and put your foot down. If it starts slipping then you need a new clutch, if not then keep using it if you want
5th gear, 40kmh, foot down. usually does the trick
Hey guys i have the same problem with the shutter so i replaced the clutch with a 3 puk heavy duty and the shutter is still there if anything its worse. Can any one suggest anything? flywheel? gearbox? It happens on take off and chopping down to lower gears.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
