Damn, that is a huge increase, NismoGTSX. I might have to reconsider it. I'd talked myself out of it, but this is good to hear. Have you got any more details of your mods?
dAVE:
I didn't notice your comment to me about Merli. Thanks for the tip. I've just spoken to him about it actually.
Nahh - its got a fair bit more than 300... Probably more like 330... It makes 300 by 5000rpm, and then broke traction past 5500rpm, so I'm not sure of it's exact figures yet. It revs to 7500....
As for how quick down the track... Not sure if I'm in a hurry to run it... I've spent god knows how much money on it to get it to this stage, and it's suspension setup is for track work...
To run a decent time, I'd have to fit an auto box, and some sicks, plus some front runners, and that's money I'd rather not have to spend...
When I end up selling it, I might spend the $$$ just so I have the slips for 10 seconds when I sell it.
BTW - MIC33R - I'm not saying that the plenum's a complete waste of money... I'm saying that for that sort of $$$ outlay, you could spend it better :)
matt
Originally posted by PVL-747
Subzero  link is below.
300rwkw is 402rwhp. that's good enough for 10's. have you raced it yet or not concerned about 1/4 mile?
Guest nismogtsx
Ihave done the following....
T3/4 hybrid
custom manifold with 3" twin dump
(i just remove the cat for racing, this way its a sleeper)
mines cams
mines ecu
nismo cam gears
gtr valve springs
port and polish head
nismo bearing kit (bottom end)
ground the crank for balance
custom fmic
tricked standard auto (no stally, i hate stallies)
some suspension work for traction
550cc HSK injectors
nismo 300zx AFM
the list goes on with lots of little stuff
but all up its only cost me about 22g's (car included)
Guest MFX_R33
I have a custom plenum on my car, but i cannot really quantify the results of just the plenum, as I did alot of mods all at the same time. It definitly helps reducing the length of pipework but at my level (205rwkw) I don't think it makes a noticable difference. Another thing you have to factor in is alot of custom plenums remove the factory idle sensors, etc from the plenum which then requires a full computer.
Pics of my plenum are here www.mfx.com.au/team/prgen.jpg
Details on moy mods are here http://www.mfx.com.au/team/pages/prg.htm
Jeff.
Guest MFX_R33
Darren at Mood Motorsports made my plenum, which I believe is a much better design than the Sub-Zero item due to the tapered design. The Sub Zero one to me looks as if it favours the first few cylinders, and would starve the last few.
If you give Mood Motorsports your manifold, they will make the polished aluminium plenum for $850. He also did my pipework and I/C for $2000. I can't speak highly enough of his work, it is excellent.
Darren Mood,
Mood Motorsports Ph. (02) 9773 0260
www.moodmotorsports.com
Just tell him that Jeff from MFX recommended him.
Jeff.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
    • Yep, looks that way. Never driven an E30 or R31 so I can only imagine
