Ok so IS Motorsport in Rockdale, MASSIVE PLUG for them, I broke down on monday near parramatta with a big idling and boost issue. I got recovered to them with no notice to to them at all, I have picked up the car today after it needed a new fuel pump and boost leaks were discovered after a smoke test.
They dynoed it and came up with 246kw at wheel with 12psi boost. The car now drives 100% and again is enjoyable to drive!
If any of you guys near sydney need someone they can trust these are definetly the guys!!!
https://www.sau.com.au/forums/topic/423409-is-motorsport/
  • 4 months later...
I can vouch for them too, Indy really knows his thing when it comes to skylines and evo's, I don't and wouldn't go anywhere else, and he'll never rip you off and will explain everything to you no matter how annoying you are with questions haha lol.
https://www.sau.com.au/forums/topic/423409-is-motorsport/#findComment-7014603
