Hey guys got my car tuned today with my recently installed safc 2. Running a turbotech v2 boost controller.
Some strange things going on here
1. AFRs lean initially even though SAFC 2 was setup for no correction
2. I set the boost the night before on 11psi but first run shows levels just under 9psi and then it goes to 11 again after. Is this the tuner removing it initially to minimise risk of problems before tuning.
3. Graph on initial run is much smoother than the final tune the hump at the end is my main concern, is this just the limit of the safc adjusting fuel and effecting timing or bad tuning or something else.as.i notice the boost drops off then almost mirroring the peak hump.
It just seems weird to me besides the AFRS are better.the boost, power and torque curves look better on the initial run.
Edited by Pattey21
at the end of the day you have given the guy a piece of shit solution to a problem.
when you tune with a safc you can only move the afm voltage up and down, its never going to be good like a aftermarket ecu.
stop complaining, and buy a decent ecu. congrats you have now learnt your lesson, just be glad a new engine is not needed.
i am not complaining saying "why isnt my graph perfect" i know what an SAFC does and that its not as good as a standalone, but they have been proven to produce good results for my modifications.
So if any people with previous experince having SAFCs it would be most appreciated.
Edited by Pattey21
Basically the SAFC is just removing the R&R and changing the mixture slightly. It is not optimising the modifications therefore the end result is whatever the engine combo spits out.
Also Anthony is a tuner and a very capable one.
Yeah thats what i was assuming, cheers
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
