Very tidy, very fast, remapped ecu, very well maintained R32.
GTR spoiler enkei wheels Stainless Steel / Ceramic Coated turbo back exhaust Split dump pipe High flow cat.
New o2 sensor Front mount intercooler Cold air intake Z32 AFM Remapped ECU
Split fire coil packs walbro fuel pump boost tee running 15psi
New water pump New clutch slave and master NISMO clutch pedal braided clutch lines with removed damper excedy heavy duty clutch
BC BR series coil overs new adjustable caster arms HICAS lock bar
NISMO extended wheel nuts open lock nuts
Enkei 17x8 and 17x9 rims good tires
8000k HIDS hi and low beam LED dash lights LED plate lights
GTR wing MOMO steerin wheel Greddy gear knob
Kenwood CD player New speakers front and rear
Car goes very well, has been remapped with Z32 and running 15psi Engine and gearbox in great condition, this car is really worth the look it is in very good condition for its age.
Car is located in Newcatle NSW, I can get more pictures or details if you require them.
Please call me on 0429 824 661 to discuss further
$8500, 12 months rego.
  • 2 months later...
  • 3 weeks later...
  • 3 weeks later...
    • yeah, there's a country that recently started importing Skylines, I blame them.
