with massive regret here comes the spill
sold in ASIS without a RWC due to the modifications (REGO TILL AUGUST 2013)
You get 1jzgte 113***km’s full major service done @105***km's zero smoke
Byteme semi-solid engine mounts
R154 5speed manual.
Heavy duty clutch
3.7LSD rear end (2200rpm 5th 100km!)
Single piece balanced Tailshaft.
HSD coilovers
Silver Firdanza Cam gears
Garrett GT30R (AKA GT3082R)
Tial 38mm gate + screamer
Stinger EMS plug n play harness and usb cable & boost solenoid to configure boost!
C’s short shifter
Recaros
Full jza70 swapped MA70 (no cut looms)
ShineAuto Rear visor
440cc injectors
Braided Brake lines
DBA slotted front disks and CPS racing pads
Braided clutch line
Viper 79DVX alarm (remote start, etc etc blah blah blah)
180dash (red leds)
JVC mp3 headunit.
Walbro fuel pump
RS*R 3.5inch exhaust to 5inch tip (super quiet for size)
now rolling on SUPER ADVANS 18" with 265 rears
eboost2
AEM wideband
No rust
new paint job.
Cons
No A/C
Passenger recaro needs retrim. (rear seats sun damage on tops)
1 minor dint on passenger door other than that straight as a dial. (minor meaning very hard to see even close up)
That’s it for problems
PHOTOS:
$9500obo
contact via pm or mobile 0429 969 695
no Astronauts and yes i am regretting this sale.
  • 3 weeks later...
    • Yep, the plan is to do some work in Japan, as I mentioned above possibly keeping it there longer than November 2025. Frankly, I'm not dealing with TopRank ever again and, because my car is no longer with them, I could work with BBL/GY directly👍 But alas, I'm not looking at major bodywork just yet.
    • Yeah I had the probes on the battery terminals.  Sounds good. What reading should I expect to see in a car that runs well?
    • I went for the scissor lift option, gives a 3ft lift at full lift. I wanted a 2 post but my concrete wasn't deep enough to secure it properly
    • Depending on exactly where that voltage is being measured, that is most likely the battery is f**ked. If the multimeter probes are on the battery's own terminals, then it is f**ked. If they are on the car's terminals, then there is a bad connection. Either are fatal to the attempt to start it. Literally just put it on the 20VDC range, put one probe on the battery's -ve terminal (ideally not the car's terminal) and the other on the block somewhere exposed/metal, like an engine mount bolt head. You can also test the earth lead is steps, so from battery to body earth, body earth to engine connection point, engine connection point to some other spot on the engine, to see if you can isolate where a shit connection actually is.
    • I meant to write 50 originally and then double checked the price and found it was ¥12m (125k) and came to edit it and realized I had accidentally added and extra 0 in the first place lol
