Hi!
First of all i did nit know where to post this so if it's not okay to post it here i guess admin will move the tread.
I am from Sweden and looking for a company in AU or NZ that sells used RB30 short blocks.
The engine was never sold in europe so it's har to get em over here.
I have tried to email RBthirty.com without any succés and now im looking for tips on a reliable scrap yard etc that might be willing to ship over seas?
I know RIPS sells with new internals etc, but it's quite expensive for me and i want to build the engine by my self.
Sorry for my bad english and i hope i can get some help.
Regards Jesse Westerlund Sweden.
Edited by Tumic
https://www.sau.com.au/forums/topic/423503-rb30-for-export/
its just a pain in the ass exporting a engine, otherwise i would help export from the UAE, its just that i don't have time or my time is best invested elsewhere...
fly to the uae, call me and il tell you where to go and you can buy them yourself and do all the work yourself... should be able to find 2 or 3 here without any issues anytime you need.
https://www.sau.com.au/forums/topic/423503-rb30-for-export/#findComment-6815111
Someone must be able to help, if I were you if be searching Holden wreckers and see if any of the larger ones are interested or even eBay.com.au
Scott
Scott
Im looking at ebay almost every day, but all the engines there are collection only.
I figure a normal person don't want to put in the time and work to export a engine, but hopefully a company will.
But the hard part is to find that company when you live at the other side of the world.
https://www.sau.com.au/forums/topic/423503-rb30-for-export/#findComment-6815112
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
    • Emissions, fuel consumption, heat, noise, etc. most likely.
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
