If they're anything like my 33, there are screws holding them on which you can only get to by removing the whole light from the car. :(
Then when you put them back in, you have to seal all around them very well or you will get water leaking into the boot.
None of this is much fun. Good luck!
(My) Cover is screwed onto the Light from behind, over / around the lense. The whole light needs to come out of the car, then remove the cover.
Paint, Fit cover, refit the whole light into car with plenty of thorough sealing around between the light and the car.
Rubber Gasket + sealant on that + sealant around the light inside the boot = No Leakage. ;)
If you don't smother it in sealant, you will regret it. Better to be safe than something else...
