Hey all,
New to the SAU forum here. :D
I've recently purchased a 1989 r32gts (nonturbo) auto for $2k
Pretty stock except the usual, pod filter exhaust, wheels..
it seem like the sump is f**ked in my car (no way to tell other then it's been bent in by a jack i guess) and apparently you have to lift the engine out a little to be able to access the sump to remove it.
if this is the case, i'll be wanting to remove the rb20 and replace it for a rb25, i have a mate who want the rb20 so no hassles getting rid of it. i was going to the swap regardless but if i have to replace the sump i was thinking of doing it sooner.
i have seen all the threads with pretty much everything on how to do the swap,yet i wouldn't be comforrtable doing it myself as i have very little mechanical knowledge, ( I'm learning!) if there is anyone on here who can inform me on how much a rb25de would cost, and also if there is anyone on here who would be able to help with the conversion that would be great. it'll most likely be done on my driveway lol.
Please leave me with some replys!
Thanks guys.
https://www.sau.com.au/forums/topic/423568-r32-rb25-swap/
you will need a complete 25de + computer+ afm etc. . available for under a grand, change the timing belt and water pump if the ks are unknown, add more $$$ for a qualified mechanis to do it for you
https://www.sau.com.au/forums/topic/423568-r32-rb25-swap/#findComment-6815988
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
