Theo ran 13.9 with 206rwkw, and yours would have to have at least 30 odd KW more than mine.
it was a 204Kw power run but its actually only running 200Kw
but yeah I had, airbox opened up with k&n filter, plenum spacer, FMIC, BOV, full custom 3" exhaust, Scotty's dump and wastegate actuator and Dale's 2.5" suction pipe on 16PSI stock turbo and fuel system. (and no brake wire mod cut!!!)
but my tune couldn't pull anymore flow out of the stock turbo.
Here's a noob problem. I've never had an auto before and I can't even work out how to launch properly off the line. I assume it's something like left foot on brake,first gear and revs held at boost but it doesn't seem to work very well?!
Hey matt, yer its not that easy, you need to be a bit more patient with them just got to find the sweet spot a go :yes:
  • Like 1
Too much rubber layered down by big boy v8's to loose any traction maybe..
As soon as I'm done tuning I'm going straight Down to kwinana motorplex to get a time.. Really hoping under 13 sec(I'm hopeful but) :-P
Goodluck. How much power are you expecting to get 12's? 12's is getting very quick..
hopefully mid 200's but this is just from talking to a few guys but I really don't know as my tuners never delt with m35's.. Just with the mods and running f-con there's no reason as long as I get a good launch I shouldnt break the 12's
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
