Theo ran 13.9 with 206rwkw, and yours would have to have at least 30 odd KW more than mine.
it was a 204Kw power run but its actually only running 200Kw
but yeah I had, airbox opened up with k&n filter, plenum spacer, FMIC, BOV, full custom 3" exhaust, Scotty's dump and wastegate actuator and Dale's 2.5" suction pipe on 16PSI stock turbo and fuel system. (and no brake wire mod cut!!!)
but my tune couldn't pull anymore flow out of the stock turbo.
Here's a noob problem. I've never had an auto before and I can't even work out how to launch properly off the line. I assume it's something like left foot on brake,first gear and revs held at boost but it doesn't seem to work very well?!
Hey matt, yer its not that easy, you need to be a bit more patient with them just got to find the sweet spot a go :yes:
  • Like 1
Too much rubber layered down by big boy v8's to loose any traction maybe..
As soon as I'm done tuning I'm going straight Down to kwinana motorplex to get a time.. Really hoping under 13 sec(I'm hopeful but) :-P
Goodluck. How much power are you expecting to get 12's? 12's is getting very quick..
hopefully mid 200's but this is just from talking to a few guys but I really don't know as my tuners never delt with m35's.. Just with the mods and running f-con there's no reason as long as I get a good launch I shouldnt break the 12's
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
