I am going to fit a set of Adj. Cam gears as soon as i do my next mod ... Turbo..
What I wanted to know is if any one had set the cam gears up to try and gain some down low/mid range power.
Top end power will be up around 200rwkw if not over with the new turbo as i figure if i loose say 15rwkw to gain a good chunk in the mid even possibly bringing the turbo on a little sooner it would be excellent for the street and really nice to drive.
I do remember reading back on SDU when i first bought my r32 a bloke with a R33 GTR set up a set of adj. cam gears to offset the turbo lag, he claimed that it actually brought the new turbo's on earlier..
Any one fiddled??
I have HKS gears on my car and they are dialed in as best as we could do. with the vg30 turbo we got noticeable gains in the bottom and top end but not much in the middle....it takes a while on the dyno to get them right but its a fairly easy task. One tip the settings for a GTR are totally different for the RB20. I would give you the specs but I am not sure how much the turbo affect it.
  • 5 months later...
Copied from post earlier today...........
by changing the overlap/separation on the inlet and exhaust camshafts you can most definitely improve the responsiveness of the engine.
However it is a lot easier to set them up for maximum horsepower, we simply run the car up on the dyno and determine where in the RPM band it currently makes its max horsepower. We then work through the combinations of advance on the inlet and retard on the exhaust until we achieve the highest reading at the predetermined rpm. We may move up a down a little in the rpm range just to make sure the adjustments have not altered the maximum power rpm point. Generally speaking there will be little if any adjustments required in the fuel and ignition maps. This process normally nets a 10 to 15 bhp increase at that rpm, but sometimes we loose as much as 10 bhp in the lower rpm positions.
Setting the cam timing up for best responsiveness is a lot more difficult as you are tuning through a range of rpm not just a single point. The way we do it is to tune as above but at the maximum torque rpm. Depending on the boots rise, we are aiming to increase the torque for at least 1,000 to 1,500 rpm around that point. We find that in order to get a good increase we need to change the ignition and fuel maps. Typically we will get a 20 bhp increase at that rpm, but loose up to 10 bhp at the maximum horsepower rpm.
Once we finish on the dyno, a road (better is track) test to confirm we have achieved not only a torque increase but a response increase as well. Our experience has been that if we have to make large changes in the ignition and fuel maps we will get a big improvement in response. Conversely if we only make very tiny adjustments, the response improvement is not as great.
Hope that helps.
I know fine tuning is required but I was after general terms until I can get it to a dyno (which probably wouldn't be soon). I've heard pretty much the exact same setting from a million people on the exhaust side but no comment on the inlet side.
Hi Joel, thought that might be the case, it's been our experience that the VG30's are now too old and out of date technology. We are going to use an RB25DET turbo hi flowed by our usual supplier (GCG) on jnr's car. But the car has changed, it's a 180 SX with the SR20 in 'er. Should be good.
ahh.. Nice.. Those GCG Turbo's definately are the way to go.
I've heard a lot of good reports about them.
I remember you first got me thinking about them.
So why the180sx? The SR20 a little bit better for a street application? More torque?
  • 1 year later...
I know this is an old old old thread, but i'm trying to find alittle something out,
When adjusting cam gears is this correct ?
1. Advancing the cam = rotate clockwise
2 . Retard the cam = rotate counter clockwise
is this correct or have i got it all wrong?
Also on the JUN cam sprockets, is each increment 1 degree or 2 degrees??
Cheers!
I found some good rules for setting up a cam;
Advancing the cam gear opens a valve earlier, and closes it sooner... retarding the cam gear, opens the valve later, and closes it later... since all you've done is moved a fixed event.
Advancing Intake and Exhaust : This will provide the car with more bottom end power, and will decrease top end. Advancing both cam gears will move overlap earlier.
Retarding Intake and Exhaust : This will increase the cars top end, but will decrease low end. Retarding both cam gears will move the overlap later and but will not change the amount of overlap.
Advance Exhaust Only : This will help the cars top end, and it reduces overlap.
Retard Exhaust only : This will help the cars mid range power, very useful for cars with big turbos / big cams. By increasing overlap, It decreases lag significantly. Doing this will bring the boost on all at once.
Advance Intake only : This will increase overlap and helps the cars bottom end and mid range power. This mod will bring the turbo on all at once.
The lift has a dramatic effect on low R.P.M. performance, but has a lesser effect at higher R.P.M.s.
Duration has the opposite effect of lift. The longer the duration, the more the R.P.M. horsepower will be boosted, but it is at the expense of lower R.P.M. horsepower.
As we all know, it's a bunch of trade offs. What one tuner might think is a good trade off, another will think its a bad trade off. That is when the debates will start.
Here are the stock cam specs from an R33 GTR, the R32 should be very similar.
Intake: 240 duration @ 8.58mm lift.
Exhaust: 236 duration @ 8.28mm lift
I cannot find anything on the timing events, if any of you have them post them up.
__________________
Cheers!
The engine turns clockwise, so if you turn the CAMS clockwise you are retarding.
Each tooth on the pulley is 15 crankshaft degrees, count the marks for one tooth.
Hope that helps :D
Is there any major differences between the JUN/HKS/APEXI/TOMEI/GREEDY Cam Gears?
Price obviously, but they all do the same job right?
I just know if any are better then others for certain reasons or is it all just branding that has the price differences.
Some people on the forums say that the HKS teeth wear out quicker. To be honest 80% of the 'big powered' Skylines i've personally looked under the bonnet of over the past month have been using HKS so it must be the minority that have warn teeth, im personally using a HKS.
The diff in price is about $30 between the cheapest and the most expensive.
Edit: Oh and heres a dyno graph of my before/after... it's ~$200 well spent.
Yeah I have heard the same thing about the HKS, I was thinking either Apexi or Tomei as they are both just a repituble as HKS. Tomei from my understanding don't use Aluminium but rather Duralium which is an alloy of it but well better quality and I think for $200 bucks ea, they are worth the buy?
  • 5 years later...
Hope that helps :blink:
i think he meant to say :
The engine turns clockwise, so if you turn the CAMS COUNTER clockwise(inside of adj cam gear)u are retarding.
Each tooth on the pulley is 15 crankshaft degrees(7.5 degrees cam) each cam mark = 2 degrees at the crank.. So when we say 4 degrees retard the exhaust cam it's actually 2 marks on the camshaft pulley. Beware of some chinese markings as the Advance and Retard are labled backwards. Check them against a photo of a HKS pulley.
Edited by BoostdR
    • I picked up my block and head last week and have been slowly assembling it since then. Pictures I took earlier this week. The rest of the auxiliaries are on now. I just have my intake manifold runners to tap for my WMI direct port setup before putting it back on. I should hopefully have the motor back in by this weekend.
    • I couldn't agree more. As an owner of a built high HP skyline, I'd be a hypocrite to not buy a Hummer for the reasons you listed though haha.
    • Hahaha oh shit! Again!
    • Is this the one? https://jpjdm.com/shop/index.php?id_product=2192&rewrite=nissan-stagea-c34-rear-boot-actuator-assembly-90550-0v000 Might be worth having a look at yahoo japan as well. Though it seems a bit odd. If the motor works itself, other than being noisy, then wouldn't it be more likely that it's an electrical issue somewhere else? And it being noisy does not seem as surprising if it has been chugging away for months
    • I know this thread is quite old, but I found it, it helped me, but I also wanted to add my experience and troubleshooting finds to the chat for others. I have not been able to open the rear hatch of my 97 Stagea for several months. Figured it had just really sealed itself up over the winter and I would just get to it eventually. Well that day was yesterday. Some time ago, I noticed my battery was going flat all the time. It was frustrating. Then one quiet night in the garage, I could hear and ever so slight humming / grinding noise coming from the back of the car. It was like a really quiet popping sound or something like sand in a very low speed blender. I took off the panels in the back and noticed the noise coming from the auto close motor, so I unplugged it and the noise stopped. And the auto close was disabled. Well, fast forward to yesterday, I tried all the tricks with power and fuse and lock and unlock and I still could open the damn hatch. So I took off the panels from the inside and found the auto lock had engaged and was stuck in close position. When plugging and unplugging the fuse, I could hear the relay clicking. So I plugged the autoclose motor back in, and the damn thing let go. And immediately started making that grinding sound again. This time, instead of just unplugging the motor, I pulled the fuse, thus depowering the relay entirely. I don't have the autoclose feature now, but at least I can open the boot and not have my battery being sucked dead all the time. Not sure what caused the motor to latch when it was unplugged from the system, but I am pretty sure it won't cause any more problems now.  If anyone has a lead on a new motor, please let me know. It's a cool feature that I would like to get back.  Hope this helps.
