hi -
Pulled off my CAS to diagnose a no start problem and discovered a half broken splined shaft in it. I tried spinning the CAS shaft by hand but it seems siezed hence why it broke the spline.
I had a look with the torch inside the exhaust cam where the CAS goes and noticed the other side of the broken spline shaft. I tried picking the broken piece with a pick tool but it wont budge.Not sure if it can.
Could someone pls explain if that splined shaft is part of the Camshaft? Cause it doesnt appear part of the CAS. how do i replace it ?
I hate to cough up on a new cam.
cheers
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/
840857_B5_7_DDF_4_C47_A293_BB7_D565_D231 FCAE778_C_ACC7_4_D64_B7_CB_625_ECEF37256
Looking into the exhaust camshaft. You can see the broken bit.
1138_B1_BB_8_CDA_418_B_B0_DA_9_EF94_E80_ D8_F97962_03_D4_4_D78_95_B7_E56_FEF6_C7_E45_FF45_F_24_FE_4923_BA2_E_724357_CCD44
first pic is the birds eye view into the CAS. You can see the broken half moon bit inside.The broken spline shaft piece which came out of the CAS
5_B5803_B9_36_E4_4_C3_E_A88_E_461_AF39_DF6_FA092_E_9282_488_D_9_FF3_921_DFFC13_F DCA4375_A_76_F8_46_FA_B606_FA1_E7_B8_E08
..The biopsy. A lot of red dust from the seized bottom, bearing after finally turning it using the vise.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6817017
Looks like you've broken the spline off the cam. The CAS spline is supposed to be female with a half moon that matches up with the male spline and half moon on the cam
cheers. So that means a new camshaft?
ps: I've posted a Wanted ad in the Forsale section for anyone that has a R32 - RB20DE camshaft and CAS. pm me if anyone can help.
Or if anyone knows where i can pick it up in melbourne.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6817506
might be a good oportunity to swap out the motor for something better, if you cant do the labour yourself then you are up for a fair few $$$
I'll be doing the labor myself unfortunately. Otherwise yeah i would consider a swapout.
I have a pair of standard RB20DET cams, which are a slight upgrade over DE, and a CAS if you need.
as long as i dont have to pissfart around with the valve clearances and electronics, timings etc...
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818074
Because they both use Hydraulic lifters there is no adjustment for the valve clearances and because the spline/drive on the exhaust cam is the same the CAS are the same.
The DET cams run eight degrees more duration on the inlet and .5mm more lift on the inlet. The exhaust cam specs are the same as the DE.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818210
you will have to pissfart around with camshaft timing and retension the timing belt-you are doing all this with the motor out?
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818401
I guess i was trying to say I need a drop in fit. Putting something non stock for the engine gets me concerned a little with having to mess with other stuff.
This is my friends car and she is on a limited budget. Trying to do it as good and inexpensive as possible.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818511
fair enough, i see where you are at, remember when it comes to cars (especially skylines) "good" and "inexpensive" are mutually exclusive terms
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6818841
I hear ya. I own an Alfa Romeo and an old school Ducati. I know the story line all too well with the exotic.
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6819236
You don't need the keyway in the cam I ran without for 3 years 400+hp no problem. They just need to be lined up in the right spot again
not sure I understand this. I believe im missing more than the keyway in the cam.
check my first two pics
https://www.sau.com.au/forums/topic/423603-r32-cas-problem/#findComment-6820431
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
