32 Gtr custom intercooler 600x310x100 cast in/out and mounts
2 x R33 sideskirts
2 x R33 front guards L&R colour Black
R33s2 front bar KR4 Grey Standard
Enkei racing rims18x8 & 18x9 2 each with new Federal RSR rubber 34&38 offset
R33 3inch stainless catback exhaust
Rb25 fuelrail and injectors Standard
R33 side blinkers X 2 (orange) L&R
R33 GTR Brembo front brakes with braided lines
Sard FPR
Adjustable camber arms front and rear R33
Prices to be negotiated as I'm in no hurry to sell but open to reasonable offers.
I also have nearly every thing to build a tough RB25 except for block and pistons any inquiries welcome
All in good condition.
https://www.sau.com.au/forums/topic/423640-r33-and-rb-parts/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
