Hi guys,
Just found out that my bottom end is fine and that the problem piston rattle..
my question to you guys which I cant find a answer for anywhere is how safe is it to drive with piston rattle.
The engine is a fresh rebuild with old pistons and rods but everything else is pretty much new.
its very faint sound to the car warms up then you can kind of hear it .
oh and its in a R32 GTR with a RB26DETT
Thanks all and if u have any questions ask me
Edited by mick1223
https://www.sau.com.au/forums/topic/423641-piston-rattle/
Well i would be getting out sorted asap. Goes to show you can't cheap out on a rebuild, ends up choosing mire doing it twice. What about the other parts you claim are pretty much new? Maybe revisit those when its apart the second time.
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6817712
Well I would consider piston slap bottom end, seriously consider a different builder it amazes me he would put old pistons and oil pump in an rb26 I'm my opinion it should have stayed in pieces waiting for new parts due to the labour involved in pulling one out and stripping it down, anyway if it were mine I wouldn't drive it.
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6817805
Why does everyone say bottom end. I just had my bottom end done.
Is it really that unlikely to be piston slap
the pistons ARE part of your bottom end anyway!
wether it be pistons or bearings that motor is waiting to fail
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6818397
Simple answer, because pistons ARE part of the bottom end, something you need to understand unless you want this workshop to continue feeding you horseshit.
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6818426
When an engine is built, critical tolerances are measured, including bore to piston clearance.
If your engine was assembled with that out of spec, I would run as fast as possible from that guy!
+1
Hence why it should be built with new Pistons and Rods.
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6818595
Yep +1 to Steve/Nick
Piston slap just means it was a shit build to start off with. In this day and age there shouldn't be any at all if the motor is built to correct tolerance.
Agree.
I paid a good machinist to do my bores for this exact reason. Am using CP's in an SR and they are dead freaking silent.. They measured the pistons themselves and determined the bore size from there.
I've heard enough SR CP slap stories to last me a life time. Cheap shit builds.
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6818628
^^ at least with new pistons there would be a valid warranty claim- using secondhand pistons the original engine builder could tell you to get stuffed, im all for using secondhand parts but im aware that im taking a chance
https://www.sau.com.au/forums/topic/423641-piston-rattle/#findComment-6818836
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
