Nope does not have the button, however mine comes with the DVD player linked into the MFD via RCA cables
which year is ur BNR34? very neat and clean set up u have there btw :thumbsup: how do u switch to TV/video input if u dont have the tv button?
A grey video in cable. Just have to put a plug on it if I wanted to use it.
any chance u got the part number?
been checking thru nissan fast but I cant confirm anything :sweat:
I'm actually trying to sell both: MFD with tv button and clarion video cable. I also have the main harness and MFD cover. I can't decide if I was, am, will install everything in my BNR32. <br /><br />I'm willing to part the video loom if you want it though<br /><br />Sent from my SC-03D<br /><br />
To be honest with you, my car left Japan Last week and is currently on a boat to Aus.... So I've got photos, but haven't actually tried using the DVD/TV yet.. my auction sheet has navigation/TV written on it...
Mine is a 99 Vspec, Build date June, auction grade 4B, 107,000K on the clock! Prob one of the cleanest interiors I've ever seen. Just goes to show that most GTR's with a claimed 50K on them have had a odo haircut!
In the pic attached, there is an adapter pocket located just to the left of the centre console which plugs into the DVD unit. It's used for a digital set top box/ or navigation.
djvoodoo: mind if i ask how much u paid for it? damn...it looks nice!! anymore pics? :) once u get it...could u try the TV/navigation thing and update us? :) am curious how the switching works without the TV button.
Pics attached :-) Yep, will try it out and see what it does!!!!
I'll PM you.
  • Like 1
The wires just go into the rear loom connector of the MFD so no PN.
Probably an adapter loom if you ask me...
similar to the clarion adapter mod i'm guessing... did u add anything to the video in? reverse camera?
Edited by C4a0s
I've got a NTFS reverse camera hooked onto my MFD, the camera itself is powered by the reverse light, so whenever I put into reverse, my reverse light would come on with the camera :)
  • Like 1
I have the optional GPS unit in my centre console, and it is annoying because now I can't buy a deck to fit in the bottom slot without cutting the surround.
i have a TV in it (which doesn't work obviously) but no TV button. It also has GPS which doesn't work - unless I drive to Japan. I wish I could get the TV and GPS to work in Australia. Would be awesome if it could be reflashed or altered to work here because at the moment that whole part of the centre console is useless to me.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
