Hi guys
After a stock cat back still for my 34 gtr
Also after a straight gtr bonnet
Split fire coil packs for 34 gtr (same as r33 s2)
Carbon fibre rb26 cam cover
Worth a try to see if anyone has any here before i buy some stuff new
https://www.sau.com.au/forums/topic/423693-r34-gtr-parts-plus-split-fire/
Do you only want Splitfire? How about some brand new Yellow Jackets for only $430 shipped - http://www.performance-wise.com/userimages/procart28.htm
Great value for $$ and come with a 2 year local warranty.
Thanks but thats the reason im going to splitfire. Had 2 Yellow Jackets die in 300km of driving
what you willing to pay for bonnet?
Do you have any pics? depends on condition
There was a Nismo Sport cat-back exhaust F/S here on SAU a little while ago. Twas for a R34 GT-R.
I also thought that the Yellow Jackets crowd honoured their warranty (if you have proof of sale & the wty period hadn't expired).
Um...ok. so your previous claim that they failed after 3 months is false then?
I never said they failed after 3 months of driving. I said i had 2 coil packs die in 300kms of driving
My bad. So your claim that they died after only 300km of driving is false. The way you worded it makes it sound like the coils were only 300km old.
When in fact they are probably much older and who knows how they have been treated,
  • Like 1
They were on the car when i got it and i dont have any paper work for them . They could be pretty old im not sure.
I wouldn't blame the Yellow Jackets then, since they're of unknown age/kms.
I've known Splitfires NOT honour their warranty - and Just Jap who sold them were pulling their hair out! Those Splitfires were only 145Km and 2 days old!
AFAIK, Super Spark and Yellow Jackets always honour their warranty - sometimes when there was a fault in the car!
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
