  • Replies 160
Posted Images
So an update on my injury. It was getting much better. Could lift my arm out sideways up till it was about level with my shoulder. Then at work yesterday I felt something pop in my shoulder and all the pain was back and I couldn't move move my arm out sideways at all. Went to the hospital after work. Got xrays done (this was the first time getting medical attention on the injury since I crashed, other than the ambos giving me a quick check over). Nothing out of place in the xrays. Then the doctor checked me out and thinks I have a partial tear/separation in the outer of the 2 bicep muscles. So I have to not use my arm for a week (which is hard when you have a job that is somewhat physical)
Did they look at your supraspinatus at all?
Shoulder abduction is its primary movement (specifically the initial part of the movement) so it would seem more logical that it is the issue...
Sounds like biceps femoris to me.
Your common peroneal nerve goes right through that area, its possible for the epineurium of the nerve to adhere to the fascia of the muscle and cause twinging with certain movements. Or it could simply be being compressed by the muscle.
get someone to do some neural tension testing on you like straight leg raises whike biasing certain nerves and see what they come up with.
This...
Not being able to move arm past shoulder height is usually inflammation of supraspinatus...however there's likely an underlying issue that caused that in the first place; probably acromioclavicular issue.
No they didn't. I'm actually thinking it's more deltoid than bicep or suraspinatus, but there is definitely something going on with my bicep as well.
This...
My arm movement was slowly increasing. Everyday I was able to move my arm higher than the day before. As it is now I can get my arm to about 45 degrees (after I hurt it again on Saturday it hurt the moment I tried to move it in abduction.
The pain I get when I try to move it was shooting down my arm from my shoulder to my elbow. I'm guessing that's why the doctor was looking at my bicep. Now the pain is more around the outside of my shoulder (which is why I'm thinking deltoid). I was also under the impression that the deltoid was more responsible for lifting the arm through the majority of the arc up to horizontal, other than the initial movement which is the surp.
I do also have a small amount of inflammation and tenderness around the base of my shoulder blade. This was there from the initial crash, and didn't change when I aggravated the injury on Saturday (in fact it may have sped up the recovery). It was causing me all sorts of grief as it was pretty painful to start with which made sleeping uncomfortable as it hurt to lay on my back, either side or stomach.
Did you have your injections Leesh?
I've got a physio appointment today where she's expecting me to run on a treadmill for a while an see how it all looks (gait anaylsis) but I'm in two minds about if I do it given the hammy/lower back.
Speaking off, given I've done no leg work for well over a week now, no walking, nothing. I've even been bending over very carefully (weight on the other leg) and just generally protecting the hammy as much as I can, the twinge is slowly subsiding little by little. When the twinge is gone from every day activity I'll get into some stretching for it and take it from there, this is what I mean when I say reset the area which I think I mentioned once before. Stop ALL activity, wait, stretch, begin build up activities etc.
Takes a while but seems to work.
I also had a fairly uncomfortable myo session including some dry needling that actually made me jump a few times and I never have before so it was fairly tender in there.
Hey Dan
No I just got some anti inflammatory tablets and will wait until after trigger point on Monday then reassess the situation. It's feeling better, still in pain but I can move my arm more freely now; just hurts alot at night time/trying to sleep.
Good luck with your physio appointment.
So hard to give up all form of exercise. Last night I really had to distract myself from the fact I wasn't at the gym (when I think about I get really upset and teary). I know deep down that I am doing the right thing though.
I'm using my foam roller now and bands for stretching and hopefully I can get back into gym in a couple of weeks, fingers crossed!
So after seeing someone else today it's confirmed thoracic spine injury. Now I need help with next course of treatment? Booking chiro tomorrow; is this the only source of treatment I should seek out now? I do have another trigger point booked next week which I will just go to because it's not going to do any harm. Pretty devastated at the moment :(
    • Nah, just take the other one off too
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
