  • Replies 160
Posted Images
Hahaha awwwww Dan!
If it helps I'm feeling the exact way about my shoulder blade atm
The thought of slicing it open is actually relieving to me lol
However, since my last physio visit on Friday (this physio was a hundred times better) it's actually feeling better than it's ever been. She said she hasn't come across someone so stiff in the thoracic spine before :( She loosened me up and manipulated me. I had an intense migraine for 2 days but feeling a lot better today; just constant cracking.
Thorasic spine mobility v important.
This wisdom makes for bullet proof lifts
  • 3 weeks later...
So an update on my shoulder shit!
I consulted an orthopaedic surgeon about my shoulder issues, who had me get another ultrasound and saw nothing out of the ordinary (I really wish someone would just spot something immediately obvious about my shoulder so we knew exactly where it was coming from!) besides some slightly inflamed tissue beneath the acromioclavicular joint. Rotator cuff looked healthy and my external / internal rotation is fine. I asked him if he thought we should do an MRI. His answer was that an MRI can be a bit like casting a net out into the ocean: it will show a bunch of potential irregularities that may not be the source of the issue and therefore of little use in this particular case.
His suggestion, based on his/my/physio's opinion that the acromioclavicular joint could be the source of the pain/inflammation, was an ultrasound guided cortisone injection to be used A. as a diagnostic tool and B. as a potential fix. The theory goes, that if we can locate the source of pain by stopping inflammation, then we at least have a narrowed down place to look for surgical options...unless the cortisone itself fixes the issue altogether.
If you haven't had a cortisone injection before, it's a rather weird experience. Long needle goes into shoulder, they wiggle it around inside you until they find the sweet spot, then inject a shitload of liquid into a space that doesn't exist, feeling like they're blowing a balloon up inside you. No real pain, just a lot of pressure. Though I'd just had a wisdom tooth out and that gave pain a new meaning, so perhaps comparably it was nothing. Straight after injection I go back upstairs to the surgeon, who tests my shoulder mobility and strength.
Got told to give the cortisone a couple of days to do it's thing and then try exercises that would normally inflame the shoulder; obviously nothing horribly strenuous, but enough to activate the joints and muscles for what would normally cause inflammation.
So I gave bench press a go and, that night, no real pain or inflammation. The next day also went quite well. Cortisone is obviously doing it's job of staving off inflammation, but I guess my concern now is if the drug is masking the underlying issue at hand that would otherwise be inflaming tissue...given it is the body's natural response to injury. I worry that I may develop bone spurs or something because I have no real telltale, besides regular ultrasound and tests for mobility, that I may be damaging the shoulder. I am, however, consoled that nothing is strikingly obvious to the GP/physio/surgeon who have all seen an ultrasound of the shoulder, therefore I haven't done anything major yet in terms of damage and movement remains quite healthy.
Have retained 90% of my bench strength, with 90kg for 6 reps, which isn't bad considering I've done no shoulder exercise for 6 months. Could push harder, but honestly I'm just glad to be exercising shoulders and chest again. Also gave my favourite shoulder press a go just to test the movement and everything checked out on a light weight. Will continue with it as I see fit and able.
Also, just a refresher: I believe this injury developed from going too hard too soon on the heavy bag when I took up boxing, as prior to doing this I have never had a shoulder injury in the 10 years I had been exercising. I was putting all my weight behind my right crosses and practising hooks with little in the way of tuition. Combine this with my routine of working shoulders heavily 4 times a week, and it's no surprise I developed a clicking in the right shoulder that didn't get worse but also didn't get better.
Then one day a warm up on incline press gave me a nasty pop followed by severe inflammation of the supraspinatus. I slowly regained mobility in the shoulder over a few weeks, however I retained some slight chronic pain in the shoulder that would be worsened with upper body movements at the gym, particularly shoulder exercises. Many physio visits, specialist consultations and finally cortisone...and here we are.
Moral of the story kids: take care of your farking shoulders. They are weak joints with strong muscles so they really need all the support and proper training you can give them. Don't skimp on supporting muscle exercises and for God's sake, if something seems out of place or hurts a little bit, don't exercise on it!!!
This is good news Birds!
Coming back after 6mths with over body weight for reps is great.
As for me, I'm convinced my leg issue is actually a lower back issue, like right down low above my butt crack.
I've been paying close attention while doing the work the Physio asked for and I'm really noticing some tightness and discomfort in there.
Saw a chrio today. Copy/paste from my thread for anyone else.
She took xrays to examine and said I had a functional leg length difference (only notable when not standing/loaded up) which implies soft tissue discrepancies - no surprises there. Also my pelvis is tilted forward, putting pressure on the lower disc(s) which she feels may be impinging the nerve, she also showed me that the second lower disc when looking from the front is not sitting even, so there are other imbalances in my pelvis. Also noted that my bad foot wants to rotate outwards and roll inwards, which could be a cause or a symptom of pelvis issues.
She made some "adjustments" on some special contraption of a table but I didn't feel much going on. The table raises up in sections then she pushes down and the table drops down and resets.
Keep stretching, keep walking, jogging if I want and can tolerate, no weights for now (as in squats/DL), do light core work, planking etc.
Going back in a week to see if there's any difference, if not she concurred with my plan of attack of seeing a podiatrist next.
  • 2 months later...
How's all your shit going, Dan?
I decided to visit a well recommended osteopath/physio, to get an all over body check and a fourth professional opinion on my shoulder issues.
This guy was probably the most knowledgeable sounding of the professionals I had seen (including my GP, my physio, and a well regarded orthopedic surgeon). Whilst his opinion largely sat in line with a lot of what the previous guys had said, he was by far the best at explaining it all to me. It was also good to get another opinion on the matter, as you can never have too many people tell you that you're safe to keep training. His opinion was as follows:
I have good mobility all round. Good posture and spinal curve. He sees no reason for me to have regular treatment from anyone, even a masseuse. This is, however, atypical of the osteopathic belief system that the body can heal itself of many ailments on its own and shouldn't depend on regular treatment from others unless significant injury or pain.
I told him about my clicky joints, e.g. hips, knees, shoulders etc. He said "It's completely normal, as long as there is no pain, some people are just built like this and it often comes with age and general wear and tear". Clicky-joint-syndrome, for lack of a better term. He explained a lot of them as tendons simply hopping over bone, which isn't an issue, provided that there is no pain from it. As for the shoulder, he believes that to be a subluxation (slight and regular dislocation of a joint) of the rotator cuff. He says there's nothing I can do about it, besides strengthening the supporting muscles and taking care with my technique; that I should just live with the muscle inflammation I get from it and dose up on nurofen/ice when it gets bad. We can't do surgery, cause we can't pinpoint where the issue is and it's not enough of an issue to warrant it, as he is satisfied with my shoulder mobility and strength. He didn't see the need for regular ultrasounds to monitor the area either (though I may still do this every few months).
An interesting opinion he had on lack of flexibility (in fingers, for example), was that it can be a good thing for what I'm doing (weight training). He said it gives the body a degree of firmness and rigidity that actually protects it from injury. Anyone agree/disagree with this? I hadn't thought of it before and always thought "more ROM/mobility the better", but with the way he explained it, it kind of made sense not to be overly flexible.
So yeah, that was good to get another all clear from a professional. Though in some ways I want nothing more than a professional to look at my scans or shoulder and say "there's your problem" / know exactly what is up. Looks like I just have to keep everything up until something is actually obviously wrong, cause people just keep turning me away lol
This latest dude was very good at explaining how joints work though, which gave me lots of confidence in his opinion, unlike the others (even if they all shared much the same opinion).
Following this, I'm now at a 112.5kg bench - only 5kg off my old pb pre-injury - so any luck I will see a new pb soon and this shoulder shit can be nothing more than...a slight pain in the bum (shoulder). Hah, and I thought you were Tom Clancy, Dan...
Slowly, physio says my back is feeling looser to him, a good thing, but because I'm using it so heavily lately with house projects etc it's hard to tell.
I'd say the frequency of which I get the sharp debilitating stab has lessened somewhat.
My glute medius strength has substantially improved through the band work he asked me to do which will help stabilise my pelvis.
I'm seeing him again tomorrow so I'll have another update then.
In the meantime I've just being doing regular bench, chins, dips and some calf raises and lunges to keep everything moving. Plus all the house project work.
Good to hear your doing a bit better dan.
Birds, I think your physio would have been talking about hypermobility, I'm not going to explain it, google is good for that.
I am borderline in some of my joints, but it can be a good or bad thing, its protected me from some injuries but caused a few as well.
For what its worth I agree with what your physio told you about lack of flexibility and strength training has definitely helped me with the joints that are affected by it.
Nothing really to report back, he said it continues to feel slightly better to him but it will be hard for me to tell as I continue to inflame it with various house projects.
Continue on as before.
I might try and take a little break over xmas from gym and projects and rest it.
  • 4 weeks later...
Got my MRI back, looks like I've got a protrusion on the disc, is that called a herniated disc or is that something different?
Physio said we can work on "managing" it through core strength and wants me to get stuck in straight away while I decide if I want to go that route longer term or opt for surgery. He said there are some good conservative surgeons he knows in Melbourne who will do a microdisectomy (I think that's what it was called) and cut that 5mm protrusion off and sew me back up.
He said I'm the perfect candidate for it and should see immediate relief as the rest of my back is in good health. He also said he rarely recommends surgery and only suggests it if he thinks it will have a extremely positive outcome.
That said he's happy for me to work on managing it for the moment.
I'm assuming I did this that time I was squatting and something went pop and I was in bad pain, but I got over that eventually with rest and stretching. I realise it's not the disc that causes the pain, but the impingement on the nerve.
I've read a bit that said stop all exercise other than walking and it will heal slowly, but he said protrusions do not heal and that the upper body work I'm doing at the moment, flat and incline, chins and dips, will have no impact on it.
I think I have the prolapse in this image.
Thoughts?
Edited by ActionDan
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
