  • Replies 160
Posted Images
So an update on my injury. It was getting much better. Could lift my arm out sideways up till it was about level with my shoulder. Then at work yesterday I felt something pop in my shoulder and all the pain was back and I couldn't move move my arm out sideways at all. Went to the hospital after work. Got xrays done (this was the first time getting medical attention on the injury since I crashed, other than the ambos giving me a quick check over). Nothing out of place in the xrays. Then the doctor checked me out and thinks I have a partial tear/separation in the outer of the 2 bicep muscles. So I have to not use my arm for a week (which is hard when you have a job that is somewhat physical)
Did they look at your supraspinatus at all?
Shoulder abduction is its primary movement (specifically the initial part of the movement) so it would seem more logical that it is the issue...
Sounds like biceps femoris to me.
Your common peroneal nerve goes right through that area, its possible for the epineurium of the nerve to adhere to the fascia of the muscle and cause twinging with certain movements. Or it could simply be being compressed by the muscle.
get someone to do some neural tension testing on you like straight leg raises whike biasing certain nerves and see what they come up with.
This...
Not being able to move arm past shoulder height is usually inflammation of supraspinatus...however there's likely an underlying issue that caused that in the first place; probably acromioclavicular issue.
No they didn't. I'm actually thinking it's more deltoid than bicep or suraspinatus, but there is definitely something going on with my bicep as well.
This...
My arm movement was slowly increasing. Everyday I was able to move my arm higher than the day before. As it is now I can get my arm to about 45 degrees (after I hurt it again on Saturday it hurt the moment I tried to move it in abduction.
The pain I get when I try to move it was shooting down my arm from my shoulder to my elbow. I'm guessing that's why the doctor was looking at my bicep. Now the pain is more around the outside of my shoulder (which is why I'm thinking deltoid). I was also under the impression that the deltoid was more responsible for lifting the arm through the majority of the arc up to horizontal, other than the initial movement which is the surp.
I do also have a small amount of inflammation and tenderness around the base of my shoulder blade. This was there from the initial crash, and didn't change when I aggravated the injury on Saturday (in fact it may have sped up the recovery). It was causing me all sorts of grief as it was pretty painful to start with which made sleeping uncomfortable as it hurt to lay on my back, either side or stomach.
Did you have your injections Leesh?
I've got a physio appointment today where she's expecting me to run on a treadmill for a while an see how it all looks (gait anaylsis) but I'm in two minds about if I do it given the hammy/lower back.
Speaking off, given I've done no leg work for well over a week now, no walking, nothing. I've even been bending over very carefully (weight on the other leg) and just generally protecting the hammy as much as I can, the twinge is slowly subsiding little by little. When the twinge is gone from every day activity I'll get into some stretching for it and take it from there, this is what I mean when I say reset the area which I think I mentioned once before. Stop ALL activity, wait, stretch, begin build up activities etc.
Takes a while but seems to work.
I also had a fairly uncomfortable myo session including some dry needling that actually made me jump a few times and I never have before so it was fairly tender in there.
Hey Dan
No I just got some anti inflammatory tablets and will wait until after trigger point on Monday then reassess the situation. It's feeling better, still in pain but I can move my arm more freely now; just hurts alot at night time/trying to sleep.
Good luck with your physio appointment.
So hard to give up all form of exercise. Last night I really had to distract myself from the fact I wasn't at the gym (when I think about I get really upset and teary). I know deep down that I am doing the right thing though.
I'm using my foam roller now and bands for stretching and hopefully I can get back into gym in a couple of weeks, fingers crossed!
So after seeing someone else today it's confirmed thoracic spine injury. Now I need help with next course of treatment? Booking chiro tomorrow; is this the only source of treatment I should seek out now? I do have another trigger point booked next week which I will just go to because it's not going to do any harm. Pretty devastated at the moment :(
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
