  • Replies 160
Posted Images
What sort of thoracic spine injury and how did they diagnose it?
I dont know about you but if I had a spinal injury, I probably wouldnt be going to a chiro because all they do is spinal manips which isnt necessarily going to beneficial. Besides, if you have a good physio they should be able to do everything a chiro can do
Physio and Trigger Point therapist both said it was a thoracic spine facet joint injury.
I wanted to get an ultrasound last week but my GP told me to wait, maybe I should go back this week and just say I want one.
Different people are telling me different things, some people are suggesting chiro and others suggesting physio.
+1 for physio or myo as opposed to Chrio. (For me the Myo I have is head and shoulders above the physio's I've seen, they have the same anatomical understanding but also are fantastic at deep tissue massage and myofascial release techniques that the Physio doesn't go near.
I think a good SPORTS physio/Myo is better again, and there are people around my area who identify distinctly as such.
The (free) physio I see at the hospital for my ankle is always saying how great it's going but she's only thinking from a basic functionality point of view, can I walk and jog pain free for a bit? Yes then you're doing great compared to the last guy I saw who can't walk unassisted.
A decent sports centric therapist realises that you want hih level function, not just basic movement, and works towards that. I'm about to leave my free physio I think and head towards one of the sports specialists for higher level assessment and to work out how to help stop my bad foot rotating outwards and rolling inwards when load is placed on it, which f**ks squatting up badly for me, and also strains my god side as it carries much more of the load.
+1 for myo over chiro. There is one upstairs from work. I've had days where I could barely walk properly from back pain and after 30 mins on the table I'm much better. It hurts like hell while I'm getting wailed on, but afterwards I feel much better
Hammy continues to be an issue despite dropping all leg work with the exception of walking for normal daily activities and walking the dog once a night, short walk, 2ks.
I note my lower back on the same side is tight and not moving freely also, similar spot to when I had the SIJ issue.
Is there a chance the hammy is being strained by poor mobility above and below it if that makes sense?
I might go back to the myo and get another hour session and this time not train the day after it thinking it's ace.
I had dry needling done, isn't that the same thing?
It's not quite the same thing; similar principle but trigger point doesn't use needles and allows the therapist to focus on one trigger point at a time. I feel trigger point enables the therapist to get deeper into the muscle fibres.
To me your hamstring sounds like an active trigger point; referring pain either locally or to another location along a nerve pathway.
To me my hamstring sounds like aids =\
Might have to cut it off.
Hahaha awwwww Dan!
If it helps I'm feeling the exact way about my shoulder blade atm
The thought of slicing it open is actually relieving to me lol
However, since my last physio visit on Friday (this physio was a hundred times better) it's actually feeling better than it's ever been. She said she hasn't come across someone so stiff in the thoracic spine before :( She loosened me up and manipulated me. I had an intense migraine for 2 days but feeling a lot better today; just constant cracking.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
