Hey there! Selling some items as I am upgrading. All items in good working order, located in Campbelltown, Sydney.
Apexi Power FC with hand controller - came out of my series 2 gtst - $950ono
Apexi AVC-R - comes with everything - $300 ono
Nismo 740cc injectors - $600ono
Z32 afm with plug - has both mesh screens pulled out - $200ono
Walbro in-tank fuel pump - $75
Think that's it. Will do a deal if someone wants to buy several items. Thanks
https://www.sau.com.au/forums/topic/423728-rb25r33-parts-pfc-injectors-etc/
Make an offer on silver avcr and genuine z32 with plug. Also have .63 internal gate gt30 5 bolt rear housing lying around, $250. Dump/front pipe with screamer 5 bolt flange 250 ono. Custom forward facing plenum mounted on stock runners, bellmouth tubes inside $350 ono.
Just to add to the JJR part, I still have the cross over pipe to suit standard plenum as well. Either way $220 ono and i'll chuck in whatever pipes I got around here lol
  • 1 month later...
  • 1 month later...
  • 1 month later...
Still have stainless dump/front pipe to suit internal gate gt30 (5 bolt) $280. Also have dump/front pipe with screamer to suit stock turbo (6 bolt) $250. Aaand .63 internal gate gt30 rear housing with actuator $250, stainless intake pipe with fitting for bov or catch can $100.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
