Hello,
this is my rb26/30 build
by kanaris engine in melb
rb30 block - cryogenic block and girdle
cp pistons
9310 pins
upgraded loxx by cp
carrillos rods
AT1 balancer
L19 Head studs
Jun 12 main studs
9L sump ASR
Billet motorsports external oil pump kit
annual groove main tunnel
Head getting done now
2mm inlet/2mm ex valves
supertech valve springs seats retainers
ferrea valve locks
tomie 260/270 cams 10.25 lift
tomei lifters
tomie cam gears
looking at 1000hp at the engine
going in vl
  • Like 1
https://www.sau.com.au/forums/topic/423779-rb-2630-build/
I always thought running flat tops means u can run more lift.
comp ratio going to be around 7.8 to 8.1
reason that low comp - less pinging high boost ,
makes more power then high comp - all types of fuel
I notice a lot of high comp boost rb have head/studs lifting issues
allways prefer low comp high boost/ high comp low boost
https://www.sau.com.au/forums/topic/423779-rb-2630-build/#findComment-6823429
  • 1 month later...
  • 3 weeks later...
I here'd about weathering/seasoned blocks are better for hp than new block for cast iron - new block will move and flex up until 100,000km
Idea is the hot and cold temp stop the cast iron from expanding/ flexing - taxi blocks would be good idea
I left the rb30 block outs side for 6 months bare wit the girdle and just befor sent to engine shop I went to cryogenics
I believe this theory works , some might disagree
crank wouldn't think be any benefits
only cost $200 shop in melb -http://www.cryocycle.com.au/
Gerry
Edited by chairman
https://www.sau.com.au/forums/topic/423779-rb-2630-build/#findComment-6922218
  • 4 weeks later...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
