Hello,
this is my rb26/30 build
by kanaris engine in melb
rb30 block - cryogenic block and girdle
cp pistons
9310 pins
upgraded loxx by cp
carrillos rods
AT1 balancer
L19 Head studs
Jun 12 main studs
9L sump ASR
Billet motorsports external oil pump kit
annual groove main tunnel
Head getting done now
2mm inlet/2mm ex valves
supertech valve springs seats retainers
ferrea valve locks
tomie 260/270 cams 10.25 lift
tomei lifters
tomie cam gears
looking at 1000hp at the engine
going in vl
  • Like 1
https://www.sau.com.au/forums/topic/423779-rb-2630-build/
I always thought running flat tops means u can run more lift.
comp ratio going to be around 7.8 to 8.1
reason that low comp - less pinging high boost ,
makes more power then high comp - all types of fuel
I notice a lot of high comp boost rb have head/studs lifting issues
allways prefer low comp high boost/ high comp low boost
https://www.sau.com.au/forums/topic/423779-rb-2630-build/#findComment-6823429
  • 1 month later...
  • 3 weeks later...
I here'd about weathering/seasoned blocks are better for hp than new block for cast iron - new block will move and flex up until 100,000km
Idea is the hot and cold temp stop the cast iron from expanding/ flexing - taxi blocks would be good idea
I left the rb30 block outs side for 6 months bare wit the girdle and just befor sent to engine shop I went to cryogenics
I believe this theory works , some might disagree
crank wouldn't think be any benefits
only cost $200 shop in melb -http://www.cryocycle.com.au/
Gerry
Edited by chairman
https://www.sau.com.au/forums/topic/423779-rb-2630-build/#findComment-6922218
  • 4 weeks later...
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
